E body turn signal switch. Is one better than another? #1013880
06/15/11 03:27 PM
06/15/11 03:27 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
It looks like there a couple of types out there or at least they look different. I have a new one in my car that I put in 10 years ago and now its broken. I have actually not really even used it. So I need a ne wone. Is one type better than another.
Re: E body turn signal switch. Is one better than another? [Re: RUMBLON] #1013881
06/15/11 05:10 PM
06/15/11 05:10 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Mopar ones are still available. I would look for one of those. I first tried to rebuild mine by using a replacement cam. That did not work out at all. Then I found an OEM one from one of the Mopar dealers like Manicotti or Herbs or someone two years ago.
Craig
Re: E body turn signal switch. Is one better than another? [Re: denfireguy] #1013882
06/15/11 05:13 PM
06/15/11 05:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The original 70 E body switch is no longer serviced, the replacement switch has a larger hazard flasher knob.. To use it either the new switch or the column has to the cut for clearance... As mentioned buy a genuine Mopar switch... The aftermarket ones are pretty cheezy...
