OK, i'm building a 440 for the Superbird and I was hoping to button up the engine tonight but hit a snag. My new Mopar Performance cast Aluminum valve covers and my passenger side exhaust manifold both want to occupy the same space when installed. There is plenty of room on the drivers side, but the passenger side is not going at all. has anyone else run across this before?
The only way it.s even close is if I bolt up the valve cover 1st, then attach the manifold. as it gets close to being tight, it hits the valve cover.
![](/ubbthreads/images/graemlins/shruggy.gif)
