1.5 exhaust 1.6 intake rocker arm advice #1012996
06/13/11 11:26 PM
06/13/11 11:26 PM
Oklahoma City
Spraygoon Offline OP
Oklahoma City
Anyone know of a way to get 1.5 rockers on the exhaust and 1.6 on the intake without having to buy 2 sets of arms? I currently have a hydraulic 484 lift cam with adjustable mechanical cam rockers (1.5 on all). Already have taller valve covers too. Thanks
Paul Reber
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: Spraygoon] #1012997
06/14/11 12:12 AM
06/14/11 12:12 AM
AndyF Offline
AndyF  Offline
Vendors will sell mixed sets. Call up Hughes Engines and they'll take care of that for you.
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: AndyF] #1012998
06/14/11 12:31 AM
06/14/11 12:31 AM
Oklahoma City
Oklahoma City
Paul Reber
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: Spraygoon] #1012999
06/14/11 07:07 AM
06/14/11 07:07 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I just changed from stock to Crane 1.6's on all valves, and the 60ft improved by .03. Not much for all that money.
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: Spraygoon] #1013000
06/14/11 10:04 AM
06/14/11 10:04 AM
ill
dennismopar73 Offline
ill
there is not enough to gain here by doing that change, with that cam !
look elsewhere for far greater of pickup and hp
carb/cam (bigger) , gear .converter etc
if you do this make sure of the coil bind issue that may exsist??
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: dennismopar73] #1013001
06/14/11 10:17 AM
06/14/11 10:17 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you already have adjustable rockers you might want to check the true ratio of what you have. you may be wasting money by buying new stuff.
Re: 1.5 exhaust 1.6 intake rocker arm advice [Re: Spraygoon] #1013002
06/14/11 10:28 AM
06/14/11 10:28 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess that would make your cam 516/484??? Wouldn't you want more lift on the exhaust? What's the rest of the set-up? Those MP cams like a bunch of compression, high stall and tall gears to work well. If you're one of those 9:1, ex manifold, 3.23 guys the 1.6 isn't going to help anything.
Coming soon!!!!
