E-body RF fender antenna hole
#1012963
06/13/11 10:52 PM
06/13/11 10:52 PM
Posts: 3,490 Annapolis, MD, USA
Vert
Annapolis, MD, USA
So after several years I'm finally getting around to putting a correct radio antenna on my 71 Barracuda. After snapping off the junkyard antenna mast while separating it from the base, I was frustrated. I had another base with same numbers, but the cable wouldn't fit, even after some dremeling with a carbide cone. I bended up disassembling both bases (yes it can be done), and assembling one that worked. After all this, I pull out the old incorrect antenna. This is when I notice the proper antenna nut will not come close to fitting the hole in the fender. WTH? Could my fender have been replaced with a T/A front fender? so far I see no evidence the hole was welded up before.
