"Full Field" Alternator Test
#1012533
06/13/11 11:26 AM
06/13/11 11:26 AM
Posts: 202 Johnson City, TN
Haney
Johnson City, TN
I am having a no charge issue with my 73 Cuda and have a question about testing the alternator. To "full field" the alternator, I just unplug both field wires from the alternator and with two seperate wires take one alternator field post to the Negative side of battery and one to the positive side? Is this right? If the alternator is good then I should have 14+ volts at idle right?
'69 Barracuda 340 4-speed '73 Cuda PROJECT
Re: "Full Field" Alternator Test
[Re: Haney]
#1012534
06/13/11 11:44 AM
06/13/11 11:44 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Probably more than 14 volts, usually I see like 18 or so. Make sure everythinng is off when you do it and only do it long enough to do the test and DON'T rev the motor. Any light bulbs on will be toast after that test.
[Re: Haney]
#1012536
06/13/11 01:35 PM
06/13/11 01:35 PM
Posts: 18,157 Mass
DAYCLONA
Mass
No more than 14.5
[Re: Haney]
#1012538
06/13/11 03:01 PM
06/13/11 03:01 PM
Haney
Johnson City, TN
Thanks for all the input. I will test more tonight.....
[Re: Haney]
#1012539
06/14/11 08:39 AM
06/14/11 08:39 AM
Haney
Johnson City, TN
OK, I think I have a problem... Got the trust meter out last night and with the key in the run position without the motor running I have 12 volts on both field wires on the alternator. If I unplug either field wire, I still have 12v on both terminals. Is this right? I started the car and using a screwdriver, it is "magnetic" near the bearing on the back of the alternator. Is my alternator shorted?
[Re: Haney]
#1012540
06/14/11 10:31 AM
06/14/11 10:31 AM
Posts: 1,822 Colorado
denfireguy
Colorado
There is virtually no way to short the alternator stud to the field so that is not your problem. Under no load, there should be 12 volts on both terminals. With no current flowing, there is no drop across the field. With that test you have confirmed that your brushes are in contact with the field at least at rest. It could change when in motion. Short primer on how the regulator works: There is a constant 12 volts on one terminal. On the other terminal the regulator supplies a ground through a pass transistor on the regulator. The lower the voltage on the system, the lower the voltage on the field terminal it is connected. If there is no current flowing through the field, as Dayclona mentioned, there will be no magnetic field developed, no screwdriver attraction, no voltage generated in the secondary. Generally the failure of the voltage regulator is the failure of the pass transistor. It opens up. Rarely, it can short to ground making the alternator run at full current, cooking the battery. I have only seen that once in 40 years on a Volare police car. If you hook one wire to the battery positive and one to the battery negative, the only thing holding the voltage down is the battery so depending on its condition, thermal runaway can occur and voltages well over 15 volts can be generated. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1012541
06/14/11 11:05 AM
06/14/11 11:05 AM
Haney
Johnson City, TN
Last night I also disconnected both the blue and green wires on the alterator. From one of the post on the alternator I took it with a seperate wire to ground on battery on the other post i used another seperate wire and went to the postive post. With the car ideling, I still only had 12V across the positive and negative post on the battery.
[Re: Haney]
#1012545
06/14/11 07:08 PM
06/14/11 07:08 PM
denfireguy
Colorado
Alternator is bad then. Rebuild it with stuff from here http://www.alternatorparts.com/chrysler_alt_repair_upgrade_kits.htm or take your chance with a rebuilt one. They are not hard to repair. Diodes and brushes are the usual suspects. They are fairly easy to repair. Craig
[Re: Haney]
#1012546
06/14/11 07:47 PM
06/14/11 07:47 PM
RapidRobert
(1) voltmeter on alt case/stud (2) eng at fast idle (3) everything in car shut off (ex ign) esp light bulbs. (4) jump either male alt field terminal to batt neg then (5) jump other male alt field terminal to batt positive post for 3 seconds max. Read (& post) what you get for voltage & you'll hear (eng speed drops) the alt slow the eng down if it's charging.
