Re: "wave" washers for e brake pivot
[Re: 68bb]
#1012264
06/12/11 08:23 PM
06/12/11 08:23 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
They usually come in the kit with hardware.I probally have a bunch laying around in the garage somewhere.I doubt thats causing your chatter.Ive done a bunch of brakes that didnt have them and never any problem.Rocky
Chrysler Firepower
[Re: therocks]
#1012265
06/12/11 08:45 PM
06/12/11 08:45 PM
Posts: 4,961 WI
Dcuda69
WI
I'm sure I have a bunch that pissed me off or were extras from hardware kits. Put plenty together without them and zero problems. Highly doubt it would cause a "chatter"
[Re: 68bb]
#1012267
06/12/11 10:59 PM
06/12/11 10:59 PM
RapidRobert
More details on what's going on. When started/what part changes/when does it chatter.
[Re: 68bb]
#1012269
06/13/11 12:30 AM
06/13/11 12:30 AM
RapidRobert
That wave washer does keep a slight amt of axial tension on the e brake lever pin but I cant see not having it allowing that kind of racket. I'd open things up & a good visual & holler back & might put a slight amt of grease on the pin & see if it quiets down while you are in there exp if everything else looks kosher & might b able to add a thin flat washer between the pin and the back side of the shoe web to take up some clearance along w the horshoe washer that you bend on the front of the shoe web
