How to check double pumper for WOT #1012080
06/12/11 01:38 PM
06/12/11 01:38 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I would like to check the carb itself for WOT. Carb is a 750DP and I'm thinking the mechanical secondaries aren't opening up all the way. How do you check to make sure you're getting WOT?
Re: How to check double pumper for WOT [Re: 68Bullit] #1012081
06/12/11 01:46 PM
06/12/11 01:46 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i would get a friend in the car to mat the gas pedal while you look down the throat of the carb with a flashlight
Re: How to check double pumper for WOT [Re: dirtybee] #1012082
06/12/11 01:51 PM
06/12/11 01:51 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
and try moving the throttle blades. If they still open more, adjust the throttle cable position.
Re: How to check double pumper for WOT [Re: Kudakidd] #1012083
06/12/11 02:25 PM
06/12/11 02:25 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Correct. Say the cable is adjusted correctly and far enough back however there is still more room and the butterflies still open back a little further, is there any adjustment within the carb itself?
carb [Re: 68Bullit] #1012084
06/12/11 02:44 PM
06/12/11 02:44 PM
Kudakidd Offline
Kudakidd  Offline
hold the linkage on the carb back so that the butterflies are fully open, then take up the slack on the cable.
