I just got the thing and I'm sorting thru some issues with it. The rear main was puking oil like crazy , I just replaced the rear seal and now no more leak.
The radiator was from an old junk yard car and stop leak was the only thing keeping fluid in it . I just ordered a new radiator and electric fan so that I would not worry about leaks or overheating , that would also position the grille in the correct location instead of where it was at , about 6" above the cowl.
I had to install a windshield wiper for it with all the Ohio rains we are having this year . Next is tires , I want to get rims while I'm at it.
I was hoping to postpone the investment on the linkage for awhile so that I could do some cruising with it while my 68 Cuda is in the body shop.
And no........... I don't want to burn up a tranny , that's why I ask on this site. I'm not worried about shift points in this thing , I usually shift in manually , what few times Ive driven it .
Here's what I'm waiting on for paint , then the 505 stroker gets fitted
till then , the rat rod will be the cruiser.
Donnie
