Re: WILL NOT START HOT
[Re: BATT21N]
#101127
08/07/08 02:37 PM
08/07/08 02:37 PM
RapidRobert
(1)jump the NSS terminal on the starter relay to ground(it's the one that goes to the trans neutral safety switch) & try again. (2) see if you have fire to the yellow wire at the starter relay when the key is in "start". (1) is the most likely culprit & I useually just ground it permanently rather than bother with adjusting the NSS.
[Re: RapidRobert]
#101128
08/07/08 07:25 PM
08/07/08 07:25 PM
Rapid, that is in my opinion, INCREDIBLY dangerous advice. All you'd have to do, just once, is have someone unawares start the car in gear, and off you go.
Neutral safety switches work just fine on thousands of Mopars through the years, there is NEVER any reason to disable them
#101129
08/07/08 07:46 PM
08/07/08 07:46 PM
Posts: 1,552 Mattituck NY.
FJ6AAR
Mattituck NY.
In my experience with this (if you rule out an electrical problem) is to add a spacer between the carb and the manifold. Your gas is getting to hot from sitting or is boiling from the hot nonrunning engine - hence the no start when it is hot. Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
[Re: FJ6AAR]
#101130
08/07/08 08:20 PM
08/07/08 08:20 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
NEW 318 IN A 70 DUSTER IT STARTS GREAT COLD WILL NOT START HOT . WE REPLACED THE STARTER RELAY WE CAN JUMP IT AT THE SWITCH BUT IT WONT KEY START. ANY SUGGESTIONS?????
Based on what you have written here I'm assuming you mean it won't turn over when hot. Is this correct? Not turning over (cranking) and not starting are two very different things when trying to troubleshoot.
Just look at the responses you've gotten so far. One guys suggesting you bypass the neutral safety switch and another suggesting your gas has vaporized.
My guess is that you've got a loose wire connection somewhere. Resistance in your wires will increase with temp, therefore when they are cold you are getting enough juice to turn the car over, but when warm the resistance is too high. How does your fusible link look?
[Re: Magnumguy]
#101132
08/07/08 09:54 PM
08/07/08 09:54 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
If it's rolling over OK and not starting, that's one thing, but if it barely rolls over, your starter is toast. Rebuild or replace it.
the post above yours explains why that may not be so.
