Jacking Up A Challenger #1011035
06/11/11 02:47 PM
06/11/11 02:47 PM
Portage Wisconsin
Lou_Steger Offline OP
Portage Wisconsin
When you jack yours up in the front where do you put the jack ? Where do you put the stands so the body doesn't twist?
Re: Jacking Up A Challenger [Re: Lou_Steger] #1011036
06/12/11 08:29 AM
06/12/11 08:29 AM
Portage Wisconsin
Portage Wisconsin
Nobody??
Re: Jacking Up A Challenger [Re: Lou_Steger] #1011037
06/12/11 08:32 AM
06/12/11 08:32 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
You can jack it up under the K-member or under the lower control arms. If you put posts under the frame you also need a post under the k-frame to support the engine weight.
Re: Jacking Up A Challenger [Re: DGS] #1011038
06/12/11 09:37 AM
06/12/11 09:37 AM
hyd floor jack under center of k member. Jack stands under subframe on each side & I prefer right where the subframe T's for the most support but not a deal breaker
Re: Jacking Up A Challenger [Re: RapidRobert] #1011039
06/12/11 12:00 PM
06/12/11 12:00 PM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
Anything special or very important for a convertible?
AAR cuda 71 rag challenger
