Re: T&D mockup Pic (1.625 K motion)
[Re: moparniac]
#1010081
06/09/11 10:51 PM
06/09/11 10:51 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i would not run it that close. t&d says a min of .060". i had to use lash caps on all of my t&d rocker setups.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: moparniac]
#1010085
06/10/11 12:52 AM
06/10/11 12:52 AM
Posts: 7,506 Az
Crizila
Az
I'd run the lash caps - with or without the clearance issues. One of the big draw backs to running roller tip rockers ( verses pallet style )is the high load on the valve stem due to the minumal contact patch with the roller tip. Lash caps help in that area.
Fastest 300
[Re: Crizila]
#1010086
06/10/11 01:45 AM
06/10/11 01:45 AM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
Im not trying to be smart, but that was your fault. Lash was way out if a lash cap came off... I been in your shoe's so I know what your feeling... I was disgusted, but only had to look in the mirror to see who was at fault. Bob, you think Im not aware of that.. My point(Aparently overlooked by some)was that with the additional tiny parts added to your engine, there is always a chance of bad lash settings, broken pushrods,rockers,springs which in turn will cause lots of other problem including lash caps with nothing to hold them in place,Again floating metal objects in an engine that doesnt need them is Dangerous..
[Re: Old School]
#1010088
06/10/11 02:33 AM
06/10/11 02:33 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I had same issue with my T&D rockers on the Victor heads, used shaft shims and split one of the rocker stands. If I did it again, i would get the heads bare, get longer valves to fit 2.0" install spring height, mill off the stands and use the maxwedge rocker stand blocks to raise the rocker shaft to the correct position.
