Differences L.A. and Magnum? And which is better? #1009833
06/09/11 09:16 AM
06/09/11 09:16 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
This is probably been covered many many times but I've been out of it for a while now, as well as I've never really studied the differences. Plus I've only ever owned what I think is an L.A. 360 block and the original 318 that came in my car.
Are the Magnum engines post 1980 or something? And are the blocks better and/or stronger blocks to have?
Re: Differences L.A. and Magnum? And which is better? [Re: 68Bullit] #1009834
06/09/11 10:33 AM
06/09/11 10:33 AM
scratchnfotraction Offline
magnums started in 92-93
they are a roller cam block,they have the closed chambed heads that have pedistal rockers and oil up thru the lifters and push rods.
there is a slight differance in the balance of the crank/rods/pistons
it has higher comp ratio than any of the older LA engines.
the heads are about the best flowing heads for a SB now days and are swaped on to some older LA block with some mods to make a pre-mag hybred engine.
85 started the LA engine with a roller cam and non oil thru lifters and shaft mounted rockers 89 for the roller block pre-mag 360 engines
they went to oil thru roller lifters and hollow push rods oiling the shaft mount rockers along with it oiling the old LA style thru the block/heads...oils both ways in 1990 or so.
more gain with the mag blocks as it is already for roller cam upgades
with out machine work the mag heads dont take much lift but can be worked for anything in the retro roller cam line up.
my LA 88-4-v 318 has 360 heads but as all 4-v engines had a flat tappet cam,I used all 1990 oil thru roller gear and hardware to swap in a lunati voodoo roller cam with some comp 901-16 springs
next up grade will be a set of mag heads for the LA/magnum hybred combo,it is ready to oil thru the lifters and PR for the mag head swap
the magnums have a short nose cam and no mech fuel pump,but you can get an extintion to run one with an LA t-cover.
the old LA t-cover will swap to the mag engine,heads may not have correct bolt holes for alt brackets IIRC
intake bolt angle is differant and can be redrill to LA bolt pattern to up the intake choise.
just a few things I remeber right off hand
hope that helps some
Re: Differences L.A. and Magnum? And which is better? [Re: scratchnfotraction] #1009835
06/09/11 11:30 AM
06/09/11 11:30 AM
dogdays Offline
dogdays  Offline
If you're starting from scratch look for a 5.2 or 5.9 Magnum. Many of the good points were covered above but to recap:
Magnum heads have a much better combustion chamber meaning more power from the same amount of air-fuel.
Magnums have roller hydraulic cam so no worries about breaking in a new flat-tappet cam unless you regress. And you can get the stock cam reground to a hotter profile while keeping the stock roller lifters.
Magnum blocks/cranks/rods are equivalent to the LA motors in strength.
A stock Magnum will have the "beer keg" fuel injection intake but you probably will go to a carb if this is your first effort.
Magnum blocks still use a regular distributor, you can replace the stock non-advance one with the HP distributor of your choice.
Magnum stock exhaust manifolds are pretty good.
I believe Magnums have lighter pistons and thinner rings for less drag.
Magnums have a consistent compression ratio. Older Mopar engines usually had actual compression ratios between 0.5 and 1 point lower than specified. So this means your Magnum engine will have a compression ratio very close to advertised which I think is about 9:1, a good ratio for pump gas.
Transmissions and flywheels bolt up.
5.2 Magnums are neutral balanced like all other 318s. 5.9 Magnums have a smaller amount of external balance than 360s. Even though in real life external balance hasn't presented a problem for the millions of externally balanced American V8s out there, having less is easier on the crankshaft.
So, if you are:
1. not planning to buy aluminum aftermarket heads or,
2. paying good $ to have LA heads ported, with their crappy open combustion chambers,
you are better off starting out with a Magnum.
R.
Re: Differences L.A. and Magnum? And which is better? [Re: scratchnfotraction] #1009836
06/09/11 11:35 AM
06/09/11 11:35 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Some food for thought, the crate 300 hp 360 is a stock 360 magnum with a carb intake and headers. The 385 hp version has flat top pistons for more compression, and a different cam. Hughes has kits to put a high lift, longer duration cam into an otherwise stock magnum motor, and if you shave the heads, you can duplicate the 385hp build for the cost of a junkyard 360, their cam/springs/retainers, and machine costs to shave the heads... Or $1000-1200
And magnum blocks have the ears to accept LA mounts for a bolt in deal
**Photobucket sucks**
Re: Differences L.A. and Magnum? And which is better? [Re: 70Cuda383] #1009837
06/09/11 12:20 PM
06/09/11 12:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Actually the 300 hp crate motor has a smaller cam than the stock magnum motors. The 5.2 magnum cam is slightly better than the 5.9 cam, not enough differance to go out and buy one but if you are like me and have a bunch of both sitting around it is always nice to be able to throw in a 5.2 cam in a 5.9. Also the 300 hp crate engine used a crappy M1 dual plane intake, if you build your own then the eddy air-gap is a lot better intake, combine it with some decent headers and you will be over 300 hp for sure.
I have always wanted to see a dyno (or drag strip)shoot out between a 1968 340 4spd motor and a 2001 magnum 360, both could be outfited with the same intake (air-gap)and headers (TTI) to even things up and I would put some money on the 5.9 if both were truly bone stock internals.
A few other things about those magnum motors is the heads flow about the same, mabey a hair better than an X head but the combustion chambers and port shapes are waaaaaaayy better at mixing fuel and air. Also a magnum has lighter valves. Also just to clarify ALL 318s magnum, poly and LA are internally balanced while the 360 magnum and LA are both externally balanced but slightly different from each other because the piston and rod are lighter in the magnum. All magnums use the same oil pan where the LAs had a different one for the 273 318 340 and the 360 had its own. The intake bolt pattern is totally different for LA and magnum, magnum heads can be re-drilled to use the LA intakes that are more readily available used. Magnum rods can be used in an LA but not vice versa with out a piston swap, the top of the magnum rod is slightly narrower. Cranks are the same.
Re: Differences L.A. and Magnum? And which is better? [Re: HotRodDave] #1009838
06/09/11 01:00 PM
06/09/11 01:00 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The magnum oil pan has a similar flange to the 360, you can get a one-piece gasket.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: Differences L.A. and Magnum? And which is better? [Re: 70Cuda383] #1009839
06/09/11 01:26 PM
06/09/11 01:26 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
actually early 380hp crate motors were stock truck long blocks like the 300 hp motor, but with different valve springs, cam, and a single plane intake.
also, the location of the bolt holes for the intake are the same between LA and magnum, it's the angle that's different. LA's are ~7-8 degrees from perpendicular to the head face, while the magnums are ~45 degrees from the head face (perpendicular to the ground)
and all magnums use a 360 style pan.
2017 Grand Cherokee Overland
Re: Differences L.A. and Magnum? And which is better? [Re: patrick] #1009840
06/09/11 01:44 PM
06/09/11 01:44 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
True. The Magnum crates did use a production truck block. I have owned two of the 360 crate motors.
Facts are stubborn things.
Re: Differences L.A. and Magnum? And which is better? [Re: 68Bullit] #1009841
06/09/11 01:52 PM
06/09/11 01:52 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Great information everyone. Thanks for all the replies. Here is where I am now. I currently have an L.A 360 in place right now with box stock Edelbrock heads. The cam is a CompCams EX 268 hydraulic tappet. I've had this engine in place and running now for about 3 years. I love the engine and the way it drives, but like all of us gearheads I'm ready to play more and go a little faster.
I wanna step up the cam grind a little bit, as the XE 268 is pretty mild. It's a great day to day driver but I have room to go up and keep this thing streetable (with a good idle, and vacuum for power brakes), especially if I go to a roller setup.
I've priced the XR-280HR-10 and I would have to go retro-fit of course and that puts me at just over $1000.00 for everything needed - cam, lifter kit, and everything else.
So the question is: Should I pay the $1K and stay with what I have, or start out with a Magnum block. I wouldn't mind to start out with a new block if the cost isn't that much more (in comparison).
I guess the Eddy heads I have now wouldn' work, nor the Weiand Stealth intake neither?
Re: Differences L.A. and Magnum? And which is better? [Re: patrick] #1009842
06/09/11 02:04 PM
06/09/11 02:04 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I made a post a few weeks ago asking about the cam in the 385 hp version of the magnum crate motor, and it as said that they are using the aftermarket "R/T +10" cam that's in the 230 degree duration area...not the stock 360 truck cam.
the truck cam is all done by 4800 rpm, as it's geared for low end torque, and matched with the beerkeg intake, which runs out of flow at around 4800. why would they use such a low rpm cam in a 385hp crate motor that'll spin to at least 6,000 rpm in a carb application?
Re: Differences L.A. and Magnum? And which is better? [Re: 70Cuda383] #1009843
06/09/11 03:33 PM
06/09/11 03:33 PM
dogdays Offline
dogdays  Offline
To the O.P.
Wow, your question got me a long way off track. Also almost everyone else. Wish you had said what you had first, would have saved a lot of extra typing.
Your question is basically, "Should I switch blocks to be able to use a hydraulic roller retrofit cam? I am running a 360 with XE268 and Edelbrock heads right now and want more cam. Putting a hydraulic roller in my existing block is going to cost $1000."
My answer to THAT question is, Yes, if you have a good machine shop that can bore another block to fit your pistons for a reasonable price and also if you can find a roller block for a good price.
BUT, you don't have to go to a Mag block at all. You can use an 89-93 360 roller block or the 5.9 Mag block, either one should allow you to use all of your old parts except for the new cam, lifters and pushrods. Of course you need to get the roller lifters and lifter retainers but they are available used for little money. Pushrods I am fuzzy on, the stock roller lifter pushrods might even work.
R.
Re: Differences L.A. and Magnum? And which is better? [Re: 70Cuda383] #1009844
06/09/11 04:26 PM
06/09/11 04:26 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
stock long block EXCEPT The cam...early 380hp crate motors used stock pistons, not flat tops. later ones used flat tops. IIRC board member Zippy has a pretty good understanding on the history of the magnum crate motors...
cam in all the hotter magnum crate motors was IIRC 288/292 adv ~230@.050 on the intake, and .512" lift for both lobes on a 108CL
Re: Differences L.A. and Magnum? And which is better? [Re: dogdays] #1009845
06/09/11 04:29 PM
06/09/11 04:29 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
To the O.P.
R.
mag block (except for EARLY production ones) will need the #2 and #4 cam journals drilled for head oiling, or you'll have to plumb the heads externally like a big block indy head, or you'll get no oil to the rocker fulcrum with LA heads.
what do you have for pistons currently? does your existing rotating assy need to be refreshed?
Re: Differences L.A. and Magnum? And which is better? [Re: patrick] #1009846
06/09/11 06:30 PM
06/09/11 06:30 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Dogdays, this is all info that I needed anyway, so nobody got way off track, nor can there be too much typing on Moparts.... right??? I'm really glad to have this thread now with all this good info, so Thanks for your time, and Thanks to everyone else.
Patrick, my current rotating assembly is good. Had it about 3 years now with ocassional driving and one time down the strip. Probably have like 2000 miles on it, tops. Nothing wrong with it beyond normal engine wear. Sounds like maybe I'm ok to keep this block, and maybe better off money wise to just continue on with what I have?
Re: Differences L.A. and Magnum? And which is better? [Re: 68Bullit] #1009847
06/09/11 06:39 PM
06/09/11 06:39 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
Why bother switching blocks at all. There are hyd. roller lifters that can fit into the old blocks. Check mancini racing. Or cheaper yet, stuff a hotter flat tappet into your engine.......
Re: Differences L.A. and Magnum? And which is better? [Re: dartgame] #1009848
06/09/11 06:47 PM
06/09/11 06:47 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
No doubt, but I don't really see a grind that I like above the XE 268 in the CompCams flat tappet line. The 274 might still be available and if so, why change it then (to just a 274, for no more gain than a 274 will give me over the 268), then there's the 284 that will take away my good idle and maybe even a portion of my power brakes. So, this is why I'm thinking of going roller with the CompCams because I DO like the grind of the XR-280HR-10, and how this particular cam will keep me streetable, etc.
Of course, as far as flat tappets, I could venture into another brand besides CompCams to see if there is something I like but I also think if I'm gonna change it, to just change it to a roller and quit worrying about special oils, and the general worries of flat tappets, etc.
Regarding the heads on the Magnum engines..... Are they as good as stock Edelbrock heads that I have on my L.A. application????
Re: Differences L.A. and Magnum? And which is better? [Re: 68Bullit] #1009849
06/09/11 07:28 PM
06/09/11 07:28 PM
upgrade to a pre-mag roller block or retro fit you block for roller lifters which are more $ than stock roller lifters.
ues the edelbrock heads on the pre-mag roller block to retain the LA style oiling to the shaft mount rockers.
edelbrocks are better than mag heads in more than one way,lighter,can run higher comp ratio,flow better,look better
you can use all the stock roller lifters and hardware in a pre-mag block with any of the retro roller cams.
my high mileage 88 pre-mag 318 with LA 360 heads got some high milage 1990 roller lifters and hardware back in 07' with the lunati roller cam and comp 901-16 springs stock retainers/locks/seals
pushing almost a full 300,000 miles(heads never off) and drive it hard everyday and not a single problem with it yet...worn rings is another story though
cheaper to run stock roller lifter in a stock roller block,you can get new replacements for around 100$ at the mopar dealer.
retro fit may need some block clearance/grinding to fit the link bars in.
you can check with member OU812/IMM-brian he has some nice drop in rollers that have had some mods done to correct some short falls of the roller lifters like longer skirts,bearing oiling,oil groove in lifter,link to intake side not the block side ect..
need to do all the home work to save some cheez then decide on whats whats
pick up a god used pre-mag engine and build it then swap and have a good spare engine
Re: Differences L.A. and Magnum? And which is better? [Re: scratchnfotraction] #1009850
06/09/11 11:24 PM
06/09/11 11:24 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd look at the comp XE275HL if sticking with a flat tappet. for a roller, look here
hughes/crane retrofit hydraulic rollers for $399
or here:
hughes retrofit hydraulic roller ifters for $354
or here
hughes solid roller lifters for $305
Re: Differences L.A. and Magnum? And which is better? [Re: patrick] #1009851
06/09/11 11:53 PM
06/09/11 11:53 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Hey Patrick what about the actual stick? Any recommendations on which cam to go with those lifters? BTW, those lifters are all at a great price
Re: Differences L.A. and Magnum? And which is better? [Re: 68Bullit] #1009852
06/10/11 11:03 AM
06/10/11 11:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what's the rest of the combo (gearing, converter stall, tranny, compression, intake, carb, etc?)
