valve stem seal question #1009578
06/08/11 08:49 PM
06/08/11 08:49 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
I am putting my heads together and ORiellys had these on the shelf (#3)thanks for the image...are you guys down with these seals.I had the #1's but would have to order those from Summit.Thanks engine is a low deck.Seemed to sweet to have those in stock
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: valve stem seal question [Re: 451 D*O*D*G*E] #1009579
06/08/11 09:46 PM
06/08/11 09:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Check the fit on the guide first. If your guides have smooth sides as opposed to the grooved sides, then that seal may not grip it well, and may work it's way up onto stem to free float. Not good. What heads?
Re: valve stem seal question [Re: buildanother] #1009580
06/09/11 08:56 AM
06/09/11 08:56 AM
Hr up from KCK
Hr up from KCK
Irons stockers with over size valves,I dont have the knurled surface.I think i'll take them back and order the #1's.Those were what was on my engine and all were still on the guides..thanks man!!!
Re: valve stem seal question [Re: 451 D*O*D*G*E] #1009581
06/09/11 10:08 AM
06/09/11 10:08 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If you are running 3/8" valves that are .015" oversize DO NOT use these seals
Do yourself a favor and get the right seal!!!
Teflon seals are too tight initially especially with .015" oversize valve and can cause accelerated guide wear.
I offer Viton positive style valve seals in MANY, Many sizes. PM me for more info.
