Page 1 of 4 1 2 3 4
Build me a 1000HP 400ci NA engine........... #1009484
06/08/11 07:03 PM
06/08/11 07:03 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
This is a theory question for you guys because quite simply this project well beyond me at the moment but nonetheless, I would to hear you guys imput on building an engine of this calibe given just a few limitaton.
Must utilize a stock bore spacing 400 Block.
Must be naturally aspirated
Must utilize the 3.38 stroke or smaller.
The rest is up to you guys. Tell me what works, what won't. Have fun with it and any good info is welcome and appreciated
Oh, and I am aware of the 1000HP stock block breaking threshold so no warnings are needed there.
Adriel Paradise
Substation Design Engineer III
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009485
06/08/11 07:08 PM
06/08/11 07:08 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Full tilt Predator heads and all associated parts. Wind it to the moon. Then watch it all scatter into pieces.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009486
06/08/11 07:14 PM
06/08/11 07:14 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Look at it another way-------- you're asking a n/a 400 cu. in. engine to live & produce more than 2hp/cu in.. Given those restrictions & parameters, IMO, it can't be done-next project!
Re: Build me a 1000HP 400ci NA engine........... [Re: topfueldart] #1009487
06/08/11 07:15 PM
06/08/11 07:15 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Not enough CI for predator heads IMO. Fully ported B1's and spin it to 9500. Ask Bob Mazzollini, he did it.
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009488
06/08/11 07:19 PM
06/08/11 07:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Re: Build me a 1000HP 400ci NA engine........... [Re: moparniac] #1009489
06/08/11 07:23 PM
06/08/11 07:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009490
06/08/11 08:19 PM
06/08/11 08:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have my reservations the block would survive. It would take a Predator or B1 PSO head to do it I think, along with sky high compression and RPM. I also think the valvetrain would destroy itself before you got there trying.
How large a cam core can you machine a factory block out for?
Alan Jones
Re: Build me a 1000HP 400ci NA engine........... [Re: LA360] #1009491
06/08/11 08:27 PM
06/08/11 08:27 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Why on earth would someone spend $20k in top end and not spend $5k for a block is beyond me.
Re: Build me a 1000HP 400ci NA engine........... [Re: Bigcube] #1009492
06/08/11 08:30 PM
06/08/11 08:30 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
patterson can build u one,or bondo bob could sell u his
Re: Build me a 1000HP 400ci NA engine........... [Re: fishy340] #1009493
06/08/11 08:47 PM
06/08/11 08:47 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Can be done. 426 guys make 900 -1000 with stock heads. Are Preddys better than S/S hemi heads?
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009494
06/08/11 08:53 PM
06/08/11 08:53 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Guys - I dont think an aftermarket block is out of the question. The given parameter is to maintain stock bore SPACING.
As for the question - thats 2.5hp/in, its gonna be tough
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009495
06/08/11 09:15 PM
06/08/11 09:15 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Predators probably flow around 100CFM more than a S/S hemi head.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Build me a 1000HP 400ci NA engine........... [Re: Pat7272] #1009496
06/08/11 09:27 PM
06/08/11 09:27 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
As for that 400, we have a bunch sitting around. I'm curious as to what can be done to increase its ability to stay together without spending the 3500+ for a block. Keep in mind this is a project for the future so this conversation is evaluating the future possibilities. My initial plan is SS/AM, my final goal is A/SMA. SS/AM only requires 9-10k. A/SMA however requires above 10k.
Essentially, we are hypothesizing a high winding motor were the valvetrain has to live. I was initially thinking that Predators or biggest B1's would be nice but both require bore sizes bigger than what can be safely had in a stock 400. I know that there is a formula or something for that relates HP potential, intake runner cc, and head flow but we all know head flow is just a number. Shape and air flow charateristics are supposed to be more important. But here is the thing though, is that those bigger heads will always choke the smaller bore engine at any rpm or that it would only choke it to a certain rpm. Also, is there not a semi machined version of either head available, if so, I could adjust valve size and ports such that its suitable for my needs. These are things I'm trying to rap my head around now so I know how to approach it later. Again any extra info is much appreciated.
PS: I though Jesel could make any valvetrain remain stable at crazy rpm's lol
Adriel Paradise
Re: Build me a 1000HP 400ci NA engine........... [Re: go green] #1009497
06/08/11 09:31 PM
06/08/11 09:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
4.495 bore x 3.15 stroke in a koleno block
plus $80k and a six pack on top
Re: Build me a 1000HP 400ci NA engine........... [Re: camastomcat] #1009498
06/08/11 09:36 PM
06/08/11 09:36 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
No offense to Bob Mazzollini, but he either doesn't run his car hard or he just doesn't make competitive power because when it comes to SS/AS, there's two other mopar guys that own that class that I could look to for help. One is the record holder and the other is the former record holder(Wes Lepold Jr and George Vignogna Jr. Both run SBM around 390's though.
Adriel Paradise
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009499
06/08/11 09:51 PM
06/08/11 09:51 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Well it's not that difficult:
Find a "230" casting 400 block
Ported Stage V Hemi head conversion
Big cam .800" lift, 290* @ .050
Twin dominator tunnel ram
15:1 compression ratio
dry sump
edit: forgot to post stock size crank and bore
Throw on some big headers and it dynoed 1008hp at 9500 floating the valves on my Engine analyzer Pro simulator lol
Re: Build me a 1000HP 400ci NA engine........... [Re: moparmanjames] #1009500
06/08/11 10:00 PM
06/08/11 10:00 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
dry sump
Thats some funny stuff right there lol. I do know that it can be done, I just don't if any of the heads available will support it.
Because Larry Pritchett's 390ish ci BBC made well over a 1000HP a year or two ago. But of course, it wouldn't be fun if it wasn't a Mopar
Adriel Paradise
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009501
06/08/11 10:12 PM
06/08/11 10:12 PM
Las Vegas NV
Las Vegas NV
dry sump
It can easily be done, Formula 1 engines just a few years ago displacing 3.5 liters (roughly 210 ci) were reving to 18000 rpm and making 950 hp.
Pro Stock trucks were 358ci and made 980hp.
It would probably be just as doable with a smallblock.
Re: Build me a 1000HP 400ci NA engine........... [Re: moparmanjames] #1009502
06/08/11 11:11 PM
06/08/11 11:11 PM
gregsdart Offline
gregsdart  Offline
This is rare air, building a motor like this, at least for me! My guess is toss around the idea of a PSO head,B1TS,or Brewers, testing to find out the minimum bore size for no valve shrouding. Then run more stroke to keep the piston dome size down. Over size roller bearing cam, Pistons, rings etc picked by the best power producer in the engine building world that you can find. Dry sump, high vacuum, every trick you can do to a crank to reduce windage. You will wind up with a rod of almost 7.10 length, rod ratio of 2.25 or so. I don't know how that will affect things, but it will have to be looked at. An after market block may have the deck thickness to reduce the deck height quite a bit. If you are certain you will try using a stock block, then a center counter weighted crank will help.
Basically, I would be looking for an engine builder with experience in high Hp comp classes, or pro stock. They would be able to sort through this stuff and figure out an engine program that will meet the goals.
I don't see a problem making 1000+ hp, just how fat the wallet is. This stuff is real high $$.
Re: Build me a 1000HP 400ci NA engine........... [Re: gregsdart] #1009503
06/09/11 05:30 AM
06/09/11 05:30 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Great thread. Greg nailed it to a tee,, I think one main ingreidiant is the seven one hundred rod to deal with the poor dwell time at rpm and rod angularity... I remember a member on here ,Hutch running a unique 383 combo with VI heads and that rod.
At RPM that S/R ratio wants to rip the pin out of the piston..
Page 1 of 4 1 2 3 4
