70 Road Runner Inside door mechanicals #1008938
06/07/11 10:53 PM
06/07/11 10:53 PM
Indiana
Beastiedoggie Offline OP
Indiana
I have the "z" shaped rods and clips, and was able to attach them easily. I have yet to place the door locks in. My problem is that when depressing the door handle plunger, there is a terrific amount of resistance. What am I doing wrong? Thanks for any help!
beast
Re: 70 Road Runner Inside door mechanicals [Re: Beastiedoggie] #1008939
06/07/11 10:58 PM
06/07/11 10:58 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
do you have the correct side lock?
Re: 70 Road Runner Inside door mechanicals [Re: moparsquid] #1008940
06/07/11 11:33 PM
06/07/11 11:33 PM
Indiana
Indiana
i am not sure if its correct or not but, they are not installed yet. I went for the z shaped bars first and then was going to install the locks....am i wrong??
beast
Re: 70 Road Runner Inside door mechanicals [Re: Beastiedoggie] #1008941
06/09/11 01:40 AM
06/09/11 01:40 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
the best way to see if there is any binding is check the action with the door panel off and see why its binding,you should be able to spot the problem.
