new carbs for 426 hemi??
#1008234
06/06/11 10:14 PM
06/06/11 10:14 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
In our on going effort to get the 1969 426 hemi to run right, my mechanic has decided that we need to try some New Carbs. The factory carbs have been rebuilt 3 times and he says they are dumping gas and fouling the plugs in short order.
What would you guys suggest in place of the carters? Edelbrock carb(s)? What model and size?
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: new carbs for 426 hemi??
[Re: ScottSmith_Harms]
#1008239
06/07/11 01:41 PM
06/07/11 01:41 PM
triple_green
Kent, WA
Just curious, what is the CFM of the OEM Carters?
Thanks!
Mark
[Re: triple_green]
#1008242
06/07/11 04:06 PM
06/07/11 04:06 PM
Posts: 3,916 usa
lewtot184
usa
Thanks!
if they're dumping fuel why don't you check the fuel pressure before you buy new carbs?
[Re: mickm]
#1008244
06/08/11 01:19 PM
06/08/11 01:19 PM
triple_green
Kent, WA
we pinched off the fuel line to reduce pressure and it still dumps gas down.
Vacuum is 17-18 lbs
[Re: triple_green]
#1008245
06/08/11 01:21 PM
06/08/11 01:21 PM
Posts: 75,343 A gulag near you.
JohnRR
A gulag near you.
You did what ? pressure is a resistance to flow ....
[Re: JohnRR]
#1008246
06/08/11 01:27 PM
06/08/11 01:27 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: triple_green]
#1008247
06/08/11 01:47 PM
06/08/11 01:47 PM
Posts: 4,179 California
mickm
California
Vacuum is 17-18 lbs
no, you need a pressure gauge in there to see what it is doing. that won't do it.
but it doesn't sound like you have found the issue. where is it dumping from? and after shutting off, or when it is running? sounds like you need to look at this closer and see what is really going on. are the floats really adjusted correctly? it's easy to take the top of the carb off and find out.
my guess is line pressure, but depends on when it is happening...
[Re: mickm]
#1008248
06/08/11 04:35 PM
06/08/11 04:35 PM
triple_green
Kent, WA
runs and then shut off and it's still leaking..after we turn it off it won't start up again...he is pretty sure the floats are adj correctly
[Re: JohnRR]
#1008250
06/08/11 04:50 PM
06/08/11 04:50 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
PRETTY SURE ???
I was just about to say that
[Re: JohnRR]
#1008252
06/08/11 07:41 PM
06/08/11 07:41 PM
mickm
California
PRETTY SURE ???
is that like being "pretty sure" the rubber didn't break??
uh-uh.....
[Re: mickm]
#1008253
06/08/11 08:15 PM
06/08/11 08:15 PM
triple_green
Kent, WA
where can I find out what the float height should be?
Thanks!
