Axle Wrap #1008055
06/06/11 08:06 PM
06/06/11 08:06 PM
Portage Wisconsin
Lou_Steger Offline OP
Portage Wisconsin
I have a '73 Challenger with a pretty stout 360. I was having cooling problems so I didn't drive it much. Now that the cooling is under control I have been driving it a bit more getting on it pretty hard once in awhile without any problems. Saturday I took it out but this time I had one person in the passenger seat and two in the back seat. I got on it really hard and it felt like something was hitting the floor pan, kind of like a cam lobe(bang, bang, bang). I slowed down and hit it hard again, same thing.
So I drive home and put the rear end up on stands and have a look. I see the balance weight on the rear of drive shaft has a small shiny spot on the side in the direction of forward rotation and a small spot at the top of the hump in the floor pan right above it. I also saw that some of the dirt on the drive shaft is wiped off as if you were to take your finger and lay it on the shaft and spin the wheels, and a small shiny spot on the top of the hump right above that.
This leads me to believe that I'm getting axle wrap to the extreme.
The springs are OE XHD Mopar springs which are about 12 years old but don't have more than 1000 miles on them. They don't have much arch to them with weight on the axle and the rear shackle looks like this _\ with the spring eye very close to the rear valence.
I need some opinions and suggestions. I am unemployed right now so money is tight. Let me here what you guys think I need to do. Thanks in advance.
Re: Axle Wrap [Re: Lou_Steger] #1008056
06/06/11 08:19 PM
06/06/11 08:19 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Does it currently have a pinion snubber? If nont its easy to make one with some tubing etc... Adjust it to where its only about a 1" or so from the stop on the floor board.
Re: Axle Wrap [Re: Lou_Steger] #1008057
06/06/11 08:29 PM
06/06/11 08:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the 2 extra butts in the back you really lower the
body and with springs that are flat the U-joint/yoke
was damn near touching then you added the roll up of
the rear... take your car to a spring shop and have them
re-arched... shouldnt cost much at all... then you wont
have some snubber ripping a hole through the floor pan
Re: Axle Wrap [Re: MR_P_BODY] #1008058
06/06/11 09:09 PM
06/06/11 09:09 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I had the rear springs rearched on my old truck & they added a leaf for about $300 and that was with them doing all of the work.
Re: Axle Wrap [Re: aquamist60] #1008059
06/07/11 12:05 AM
06/07/11 12:05 AM
Portage Wisconsin
Portage Wisconsin
Let me clarify. I can afford a new set of springs but nothing like the Cal-tracs stuff.
Should I go with the SS springs as this will be mostly street driven with a track visit once every few years or ??????
Re: Axle Wrap [Re: Lou_Steger] #1008060
06/07/11 12:21 AM
06/07/11 12:21 AM
Kirkland, Washington
Pacnorthcuda Offline
Just find a pinion snubber for the rear end. It will solve your problem.
Re: Axle Wrap [Re: Pacnorthcuda] #1008061
06/07/11 02:35 PM
06/07/11 02:35 PM
Portage Wisconsin
Portage Wisconsin
MR_P_BODY I hear ya on the re-arching but if these springs did this with hardly any miles it makes me wonder if they will do it again and then I'm in the same boat in a very short time.
As far as just putting a snubber on it' at this point that seems like a band aid for a problem I will have to address down the road.
Re: Axle Wrap [Re: Lou_Steger] #1008062
06/07/11 02:41 PM
06/07/11 02:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if you want you can put the SS springs on... I'm
just not a fan of those IF its a street car(which I
assume this is due to having people in back)... they
ride stiff... JMO.... were those springs you have
made in Mexico... those springs did have problems
which I believe was in the heat treating (too soft)
Re: Axle Wrap [Re: MR_P_BODY] #1008063
06/07/11 02:44 PM
06/07/11 02:44 PM
Portage Wisconsin
Portage Wisconsin
Yes as a matter of fact I was looking at them very closely and they were made in Mexico. If I get a new set of the OE XHD are they of a better quality now?? Thanks for the help!
Re: Axle Wrap [Re: Lou_Steger] #1008064
06/07/11 02:49 PM
06/07/11 02:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That I cant say.... I havent bought a set of springs
since I worked in the suspension lab at Chrysler....
thats been a WHILE
EDIT
You might call Mancini's and ask where they are made
Re: Axle Wrap [Re: Pacnorthcuda] #1008065
06/07/11 03:07 PM
06/07/11 03:07 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
PACman .. go wash your mouth out with soap ...
A taller PS will just make more noise !!
PROPER springs are the only solution
Re: Axle Wrap [Re: dOc …] #1008066
06/07/11 10:27 PM
06/07/11 10:27 PM
Like Mike said, the extra weight plus the acceleration made the drive shaft rub, raise the back of the car up or don't get on it hard when the car is loaded with extra weight or a lot of passengers The permenent and proper fix is to replace those springs like you want to
Re: Axle Wrap [Re: Cab_Burge] #1008067
06/08/11 09:08 AM
06/08/11 09:08 AM
Portage Wisconsin
Portage Wisconsin
I ordered another set of the XHD from Mancini. They told me they have had no problems with them. Let's hope this is true
Re: Axle Wrap [Re: Lou_Steger] #1008068
06/08/11 09:15 AM
06/08/11 09:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My son had the OE springs rearched on his 62 300 probally 10 years ago.They added a leaf also.They still work better than any new spring you can buy.Im on my second set of SS springs on my 65 B body.This time I added a extra main and clamped them.Rocky
Chrysler Firepower
Re: Axle Wrap [Re: therocks] #1008069
06/08/11 09:36 AM
06/08/11 09:36 AM
Portage Wisconsin
Portage Wisconsin
Well, the original springs are long gone so I don't have too many other choices unfortunately.
Re: Axle Wrap [Re: Lou_Steger] #1008070
06/08/11 02:05 PM
06/08/11 02:05 PM
ill
dennismopar73 Offline
ill
i will thro my 2 cents in ,i would go to naps/oboys /advance, etc
get you a pair of load helper shocks, they are shocks that have a spring on them that add app 1200 # of load cap
my 75 road runner was a 4000 # whale, with super stock springs for a 3800# car, i put those on it straightned the car up rode great, my 60'
went froma 2.03, to 1.78 /1.83 and best of all you dont see anything , and cost about 69$
just my 2 cents have a great day!!
