need help ASAP.. #1007572
06/05/11 10:26 PM
06/05/11 10:26 PM
Fredericksburg,Virginia
1 Bad Duster Offline OP
I have a 70 Duster with NOS and MSD electronics will a bad stock amp gauge cause me to have problems with stock wiring..With the car off with the power on it works fine.But soon as the motor starts.The gauge moves all over the place its works when it wants to..Thanks need help ASAP..
1973 Pro Street Duster
Re: need help ASAP.. [Re: 1 Bad Duster] #1007573
06/05/11 10:32 PM
06/05/11 10:32 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Old ammeters have been a problem for more than one Mopar. Some folks have stories as bad as fire,smoke,etc. The firewall bulkhead is another trouble spot to check out too. All of the juice goes through the connector to the amp gague and back out. High resistance(old)connections cause heat and electrical failures.
Re: need help ASAP.. [Re: 67_Satellite] #1007574
06/05/11 10:44 PM
06/05/11 10:44 PM
Thanks for the quick reply and help I will check both..
Re: need help ASAP.. [Re: 1 Bad Duster] #1007575
06/05/11 10:54 PM
06/05/11 10:54 PM
More details on how it's acting. OE ammeters are pretty trouble free & as said I'd b more worried about the bulkhead & would seperate the halves & clean the brass terminals (esp the main in/out) w a small metal bristle brush for the male ones and use a new brass terminal NAPA 725147 to clean the female ones and I'd highly suggest Nacho's simple 2 wire bulkhead bypass for the 2 main in/out wires (visualize the outside bypass lane to the right at a border checkpoint, 1 coming 1 going) but I am sidetracked as need details on what (side of 12 o'clock) the ammeter needle is bouncing.
Re: need help ASAP.. [Re: RapidRobert] #1007576
06/05/11 11:11 PM
06/05/11 11:11 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
We found this problem on a Duster my son had. Headlights worked just like a riding mower, light when running, pull up to a light, or idle, they'd dim almost out.
It was the amp gauge/wiring @ the gauge.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: need help ASAP.. [Re: Magnumguy] #1007577
06/05/11 11:20 PM
06/05/11 11:20 PM
here are some more details on what the car is doing.The gauge left and halfway.. I'am running a MSD 7531 box and a nos control and The NOS work when it wants to like something is interfering also.Thanks for the replys and help..
Re: need help ASAP.. [Re: 67_Satellite] #1007578
06/06/11 12:24 AM
06/06/11 12:24 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i had a dash fire in my 68'dodge coronet with old amp gauge, i did the amp gauge bypass and went to a volt gauge, i did the Madelectric.com bypass, works great and even helped with the dim lights at idle
Re: need help ASAP.. [Re: 67_Satellite] #1007579
06/06/11 12:41 AM
06/06/11 12:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
get under the dash and take a look. Mine was doing the same thing yesterday w/ some smoke! turned out the + wire was touching part of the frame. fixed it in about 1 minute. Those guages suck. You can bypass it by connecting the 2 wires together and that keeps all the juice form coming into the car.
Coming soon!!!!
