carburetor jetting #1007230
06/05/11 04:59 PM
06/05/11 04:59 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...main jet .095.
...if you change just the rods from .068 x .047 to .065 x .047 will it richen the cruise,wot, or both?
Re: carburetor jetting [Re: can.al] #1007231
06/05/11 05:11 PM
06/05/11 05:11 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Not likely enough difference in dia between the two rod sizes to matter much. You would need to go + or - about 8 sizes on a metering rod step to equal one jet size difference.
Re: carburetor jetting [Re: can.al] #1007232
06/05/11 05:14 PM
06/05/11 05:14 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
That rod change will richen just the cruise.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: carburetor jetting [Re: DEMONSIZZLER] #1007233
06/05/11 07:06 PM
06/05/11 07:06 PM
Dave are 8 sizes in effect(.001" X8=.008") as there's only a handfull of rods in eddy's kits & the're not graduated in thousandths. in other words would going from a .077" cruise step to a .069" b richening it 8 sizes?
Re: carburetor jetting [Re: Mick70RR] #1007234
06/05/11 07:11 PM
06/05/11 07:11 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..so sm step is wot throttle...rod highest,no vacuum
..main body is cruise....think i got it now.
Re: carburetor jetting [Re: can.al] #1007235
06/05/11 07:17 PM
06/05/11 07:17 PM
3 steps: small "power" tip on the end, "cruise" is next step up that's somewhat larger then the even larger main shank dia up to/including the L bend at the top
Re: carburetor jetting [Re: RapidRobert] #1007236
06/05/11 09:19 PM
06/05/11 09:19 PM
Stone Mt, GA.
super gas
super gas
Stone Mt, GA.
That is right Robert; The smaller the id or step on the metering rod
the richer the circuit becomes. A smaller rod id lets more gas through
the jet.
Re: carburetor jetting [Re: DEMONSIZZLER] #1007237
06/05/11 10:36 PM
06/05/11 10:36 PM
Dave I'm not grasping how 8 sizes diff on a rod dia (.008" right?) equals 1 jet size as I had went from .095"'s to .098's jets on my 1406 (a 3 tho diff). What am I missing?
Re: carburetor jetting [Re: RapidRobert] #1007238
06/06/11 08:36 AM
06/06/11 08:36 AM
Stone Mt, GA.
super gas
super gas
Stone Mt, GA.
It's not the same thing; try tuning with jets vs metering rods with a Carter using both and you will see how this is.
