Re: Dipstick Tricks - Hemi
[Re: kjh440]
#1007194
06/05/11 04:01 PM
06/05/11 04:01 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
you won't like to read this but you will probably have to remove the hemi to install the new dip stick. it can be done with the motor in the car. but your sanity will be much better if you remove the motor. if you install some of the aftermarket dip sticks you sometimes have to drill out the hole a little bit to get it in.
perception is 90% of reality
[Re: Mr T2U]
#1007195
06/05/11 08:59 PM
06/05/11 08:59 PM
Posts: 2,532 God's Country Maryland
GODSCOUNTRY340
Every aftermarket tube I've installed needed the shaft that enters the block filed down. A belt sander works great or you can use a bench grinder. Just be careful not to go too far and be sure to use a little sealer on it. You will most likely have to bend the tube a little, be sure the end is lined up straight with the hole or it will not go in.
[Re: ahy]
#1007197
06/06/11 02:36 AM
06/06/11 02:36 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I had the same trouble, broke the first one off inside the hole... I made a tool similar to the crow foot idea... This is in addition to grinding a bevel on the leading edge of the tube and using some lube to help it slide in.. Here is the tool.
[Re: MAVERICKSHEMI]
#1007200
06/06/11 05:05 PM
06/06/11 05:05 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I switched to the Hughes Engines ferrel style dipstick holder, and will never use the original style again for the reasons you guys are discussing. It is the best! http://www.hughesengines.com/Index/produ...mp;partid=11247
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
