Distributor install question #100593
08/06/08 10:06 AM
08/06/08 10:06 AM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
On my newly rebuilt engine when the #1 piston is at tdc the distributor rotor doesn't point directly to one terminal on the cap. its pretty much evenly spaced in between two of them. Would it be correct to have the #1 terminal be the one the rotor had just passed or the next one it comes too?
Re: Distributor install question [Re: ryan053] #100594
08/06/08 10:11 AM
08/06/08 10:11 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's on tdc firing cyl #1, the rotor can indeed be between the #1 tower and the #8 tower.
Re: Distributor install question [Re: buildanother] #100595
08/06/08 06:13 PM
08/06/08 06:13 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
so then the #1 tower would be the one that the rotor just passed?
Re: Distributor install question [Re: ryan053] #100596
08/07/08 12:44 AM
08/07/08 12:44 AM
chicagoland,usa
chicagoland,usa
That's it, that's the whole "before top dead center" deal. When the piston gets to the top, the spark has already fired that cylinder.
