AGM Batteries, need box?
#1005704
06/03/11 07:36 AM
06/03/11 07:36 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Moving the battery to the trunk. Do AGM batteries (Optima, etc) require a battery box w/vent? Or is a hold down sufficient?
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: AGM Batteries, need box?
[Re: Crazy68Dart]
#1005705
06/03/11 08:27 AM
06/03/11 08:27 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Batteries only require a box if the is no wall between them and the drivers comprtment.
[Re: WILD BILL]
#1005706
06/03/11 02:14 PM
06/03/11 02:14 PM
Crazy68Dart
Canton, Ohio
Thanks. So, is the back seat considered a wall?
[Re: Crazy68Dart]
#1005707
06/03/11 02:19 PM
06/03/11 02:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The seat itself... no... has to be alum or steel
[Re: Crazy68Dart]
#1005708
06/03/11 02:21 PM
06/03/11 02:21 PM
WILD BILL
BROOK PARK, OH
I doubt it and didn't consider it to be with in the rules on Gina's 72.
I removed the seat back, installed a piece of sheet metal to the cross braces just behind the seat, then reinstalled the seat.
Unless you look in through the trunk you wouldn't even know it's there and didn't take bit a 1/2 hour to get done.
I used poster board to make a template before cutting the sheet.
[Re: MR_P_BODY]
#1005709
06/03/11 02:22 PM
06/03/11 02:22 PM
Crazy68Dart
Canton, Ohio
Thanks for the clarification. I need a box, then.
[Re: WILD BILL]
#1005711
06/03/11 06:57 PM
06/03/11 06:57 PM
Crazy68Dart
Canton, Ohio
I'm using the stock tank.
The Dart will spend most of its life on the street, I just wanted to make sure of the requirements if I decide to play at the track from time to time.
Your sheet metal wall, I assume you just screwed it in place? I have seen guys weld them in, I am too far along (painted, etc.) to be firing up the welder inside the car.
[Re: Crazy68Dart]
#1005712
06/03/11 07:21 PM
06/03/11 07:21 PM
Triple Threat
Renton Washington
I have an Aluminum box in my car made by Taylor. Sealed so it passes Tech for NHRA and IHRA. $80 or so, its a nice piece.
[Re: Triple Threat]
#1005713
06/03/11 07:41 PM
06/03/11 07:41 PM
WILD BILL
BROOK PARK, OH
I think I rivted it in.
I know I didn't weld it
[Re: WILD BILL]
#1005714
06/03/11 08:08 PM
06/03/11 08:08 PM
Crazy68Dart
Canton, Ohio
Thanks guys. I appreciate the help as always.
[Re: astjp2]
#1005716
06/04/11 02:27 AM
06/04/11 02:27 AM
Triple Threat
Renton Washington
An aircraft box isn't gonna do him any good unless its sealed and vented outside the car. Needs to either, build a fire wall along the package tray and behind the rear seat (no speakers allowed). Or get a sealed battery box.
I had a firewall in my car behind the seat and they dinged me for my speakers. They were in the stock location and they said it could still burn through. So out came the firewall and in went a sealed box. Haven't had any issues at any race since, NHRA divisionals, local bracket races, ET finals etc.
[Re: Triple Threat]
#1005717
06/04/11 10:18 AM
06/04/11 10:18 AM
Crazy68Dart
Canton, Ohio
Good to know. My trunk bars go through the speaker holes. If I did it again I would have sent them through behind the speaker holes.
I'll check out the Taylor box. I think that is the one I had my eye on.
