What size radials on 15x3.5 wheels? #1005223
06/02/11 01:38 PM
06/02/11 01:38 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Please post what size radials y'all are running on 15x3.5 inch wheels. Any recommendations? Thank you.
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005224
06/02/11 01:48 PM
06/02/11 01:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not much available for a 3.5" wide rim... I assume you want a tire with a little height.. BFG still offers a 155/80-R15 which is 24.7" tall but it's supposed to be on a 4.5-5.5" wide rim... Plus the load rating is pretty low...
Moroso Front runners are designed for skinny wheels but they are bias ply tires...
Re: What size radials on 15x3.5 wheels? [Re: 1_WILD_RT] #1005225
06/02/11 05:44 PM
06/02/11 05:44 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I ran 165R15 (165/80r15), which I think was around 25.5" tall. They were the standard tire for a VW Bug. Not sure what availability is nowadays though..
Maybe check Tire rack?
Outcast Dodge guy.
Re: What size radials on 15x3.5 wheels? [Re: 85_Ram_4speed] #1005226
06/02/11 06:32 PM
06/02/11 06:32 PM
Central NC
gch Offline
gch  Offline
Central NC
165r15 or 165/80r15.I can still get them at the shop I work at from time to time.
Re: What size radials on 15x3.5 wheels? [Re: gch] #1005227
06/02/11 06:37 PM
06/02/11 06:37 PM
michigan woods
imfixinmopars426 Offline
michigan woods
thanks,i was just going to ask the same question!
Re: What size radials on 15x3.5 wheels? [Re: imfixinmopars426] #1005228
06/02/11 06:47 PM
06/02/11 06:47 PM
scratchnfotraction Offline
165/15 or 185/15
any tire shop can get a V-dub tire for you.
I think my last ones ran about 50$ a tire at the local tire shop.
Re: What size radials on 15x3.5 wheels? [Re: scratchnfotraction] #1005229
06/02/11 06:55 PM
06/02/11 06:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Goodrich still makes Radial T/A's in those sizes too.
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005230
06/02/11 08:30 PM
06/02/11 08:30 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I run 205 75 15 on my car
Re: What size radials on 15x3.5 wheels? [Re: RV2] #1005231
06/02/11 09:08 PM
06/02/11 09:08 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I have 165/80r15 and they leakdown every few days. The wheels have no damage the valve stems and tires are new. I was concerned that the tires were too wide. I haven't driven on them yet they are just mounted on a roller now. Any ideas why they're leaking down and what I can do to fix it? Thank you.
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005232
06/02/11 09:18 PM
06/02/11 09:18 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
What are the rims ?
If they are a 2 piece wheel (like Centerline autodrags,etc), they could be leaking between the halves.
(assuming the tires are tubeless type and in good shape)
Re: What size radials on 15x3.5 wheels? [Re: OzHemi] #1005233
06/02/11 09:49 PM
06/02/11 09:49 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
That's exactly what they are. Centerline Autodrags. How do I fix this problem? Thanks.
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005234
06/02/11 10:01 PM
06/02/11 10:01 PM
I have ran tubes in the 165/15 on 3.5 rims before
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005235
06/02/11 11:11 PM
06/02/11 11:11 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
There is a bead of silicone between the halves you can see with the tires off..might have scrape out the old stuff and put a new bead on. As mentioned tubes is an another thing you could try but try to reseal them first i would say..
Re: What size radials on 15x3.5 wheels? [Re: scratchnfotraction] #1005236
06/02/11 11:17 PM
06/02/11 11:17 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I'm running 165r15s on the front of my Duster and my Dart Sport. Honestly, I had a hard time finding anything in that size when I was looking for them about 3 years ago. All the local tire stores could get was some off brand foreign tires, but I wanted something nice to go with the rear BF Goodrich drag radials. I can't imagine that BF Goodrich makes a radial T/A in that size. I wound up buying a nice set of BF Goodrich Silvertown radials from Coker tire. By the way, they are on Centerline Autodrags with no leak down.
Re: What size radials on 15x3.5 wheels? [Re: pinkduster] #1005237
06/02/11 11:51 PM
06/02/11 11:51 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
They do a 155/80-15 in a BFG T/A
(They say minimum rim width is 4.5" though...)
Re: What size radials on 15x3.5 wheels? [Re: OzHemi] #1005238
06/02/11 11:58 PM
06/02/11 11:58 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I run 165's on my 3.5's with no issues. The only place I could find them local was at discount tire in their brand but I highly recommend staying away from discount's brand, the side walls are crap even with 40psi in them My car has all the front suspension replaced and with these tires it feels very sloppy. The old tires I had before these were king brand I think and were great
Re: What size radials on 15x3.5 wheels? [Re: SLOW67] #1005239
06/03/11 08:28 AM
06/03/11 08:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have 2 set of 165 80 15s.I change rims so I have a different look.One set is Kumo one sten Nexen.They run great on the street and pretty much never lose air.They were a pain to find a few years ago.Rocky
Chrysler Firepower
Re: What size radials on 15x3.5 wheels? [Re: therocks] #1005240
06/03/11 10:04 AM
06/03/11 10:04 AM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Before I mounted the tires on the Autodrags I had them mounted on some 15x4 steel wheels and they held air fine. I'm fairly certain the silicone bead is the problem. Thanks for the help.
Re: What size radials on 15x3.5 wheels? [Re: alpha727] #1005241
06/03/11 11:56 AM
06/03/11 11:56 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
