Re: Lokar or Bouchillon? [Re: 1bad318] #1004890
06/03/11 09:47 AM
06/03/11 09:47 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Hopefully John Kunkel will chime in- but I believe other than price and looks, there is a significant mechanical difference between the lokar setup and the bouchillon performance setup. Something about using the stock throttle pressure arm at the transmission with the lokar setup and it not being the correct ratio in relation to the arm at the carb. The bouchillon setup has a replacement arm with the correct ratio.
Re: Lokar or Bouchillon? [Re: 1bad318] #1004891
06/03/11 12:00 PM
06/03/11 12:00 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
i use the lokar on my cars,works great.i also work at lokar and can tell you its a quality piece and 100% made in the USA....knoxville,tn as a matter of fact and lokar has a lifetime warranty on their products.either way,you cant go wrong with either
I didnt know about the lifetime warranty.
I just yanked them out of the package and installed them. LOL
Very nice stuff though. I have the throttle and TV cable from Lokar, but I used the trans/oil dipsticks from Milodon.
Lokar is indeed a quality product though.
Re: Lokar or Bouchillon? [Re: 70Duster440] #1004892
06/03/11 09:54 PM
06/03/11 09:54 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Bouchillon here. Engineered to work on Mopars right out of the box - no fuss. Not as pretty as a Lokar. I seem to recall that the cables themselves are OEM pieces intended for trucks with A518's.
The cable that I used was a 91 Dodge van cable w/TBI A518. It looks identical to the Bouchillon. The hardware used at the trans is definately all Chrysler. bob
Re: Lokar or Bouchillon? [Re: BulletBob] #1004893
06/04/11 12:25 AM
06/04/11 12:25 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have a bouchillon. used it with a holley, went to a carter and had to modify the adapter to fit (per instructions) now i have gone back to holley and the bracket doesnt fit anymore and i am not even sure i kept the part i cut off. ooooooooops.
double oooooops. i dont have to buy a new bracket, bolted it onto the holley/mopar adapter and it works better than ever!!
happy with it. would buy another one.
Re: Lokar or Bouchillon? [Re: Pat_Whalen] #1004894
06/04/11 12:39 AM
06/04/11 12:39 AM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
the lokar piece adjusts with the cable at the carb.there is no arm.you loosen a set screw and adjust the tension on the cable to adjust the throttle pressure.but they are quiet different.but like i said,heard good from both,both work great
Re: Lokar or Bouchillon? [Re: 1bad318] #1004895
06/04/11 07:07 PM
06/04/11 07:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've got a 414/904 with a victor intake and I just ordered the Mancini kit (that i think is the Lokar) along with one of ANDYF's tall throttle brackets....Hope I have as good of luck with the hook up as you all seem to be having!
WIZE
In Car:
Re: Lokar or Bouchillon? [Re: 1bad318] #1004896
06/07/11 12:34 PM
06/07/11 12:34 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
What I was getting at is that the distance from the pivot points for each arm is not appropriate with the Lokar kit. Cable adjustment may be able to be set properly with the Lokar kit when the throttle is 0%, but as throttle is increased, the throttle pressure arm at the transmission is not moving in a correct relationship to the arm at the carb. Again, this is just from memory and John seemed to understand it a lot better. There was something about drilling a new hole in the TP arm if you used the Lokar setup.
Re: Lokar or Bouchillon? [Re: Pat_Whalen] #1004897
06/08/11 10:53 PM
06/08/11 10:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I only use a throttle cable as I have a manual shift V/B. I use the Lokar and it works great. The bracket bolts on the rear carb mounting nut so you dont need any other brackets. It has been on my 63 for about 6 years and never no trouble. Ron
