Caltracs and 2" lowering blocks #1004787
06/01/11 10:56 PM
06/01/11 10:56 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
Who makes a good lowering block that will hold up with caltracs?
I know calvert sells a 1" deal, anyone have a source for a 2" block
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004788
06/01/11 11:00 PM
06/01/11 11:00 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Mine are machined from a piece of billet, they are 1 5/8. I got them from a member here that was selling them.. wouldnt take much to make a set
Re: Caltracs and 2" lowering blocks [Re: joshking440] #1004789
06/01/11 11:02 PM
06/01/11 11:02 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Re: Caltracs and 2" lowering blocks [Re: ksj] #1004790
06/01/11 11:07 PM
06/01/11 11:07 PM
RobX4406 Offline OP
RobX4406  Offline OP
http://www.speedwaymotors.com/search-lowering-blocks.html
I've seen those aluminum ones collapse with use
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004791
06/01/11 11:27 PM
06/01/11 11:27 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"Ground Force" lowering blocks are iron and available in 2". Check Jegs.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004792
06/02/11 03:17 AM
06/02/11 03:17 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run 2" angled solid billet alum. ones my buddy made.
Re: Caltracs and 2" lowering blocks [Re: goldmember] #1004793
06/02/11 08:45 AM
06/02/11 08:45 AM
Connecticut
5126brl No more Offline
Connecticut
Go with steel or iron, I split the allum. ones in half after a few passes.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004794
06/02/11 11:09 AM
06/02/11 11:09 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Can't say I've ever seen extruded aluminum fail. bend some, yes, but collapse, no. I have seen many sets of cast aluminum shatter to pieces.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004795
06/02/11 11:21 AM
06/02/11 11:21 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I don't recommend running lowering blocks and CalTracs, especially more than 1 inch. Look at where the bottom of the link will be compared to the edge of the rim if you get a flat tire and imagine it digging into the pavement if that happens and you'll know why. If you need to lower the ride height that much, get new springs.
Re: Caltracs and 2" lowering blocks [Re: PorkyPig] #1004796
06/02/11 12:23 PM
06/02/11 12:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve heard this many times and that`s what a spare`s for although a drag for a street driven race car. Also heard they don`t work well but know of several p.s.c.a. and other racers deep in the 8`s w/em.
Re: Caltracs and 2" lowering blocks [Re: Thumperdart] #1004797
06/02/11 12:40 PM
06/02/11 12:40 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
cal tracs do not need lowering blocks!! if u bought them already,just call and tell em u want 2" below stock..it just requires changeing the back portion of the spring!
Re: Caltracs and 2" lowering blocks [Re: fishy340] #1004798
06/02/11 01:57 PM
06/02/11 01:57 PM
RobX4406 Offline OP
RobX4406  Offline OP
I don't run the caltrac mono spring.
If I did that would be a simple solution.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004799
06/02/11 02:13 PM
06/02/11 02:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Check out www.lugnutking.com He might have something in billet. He's always at the Pomona Swap meet and LB swap meet as well.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004800
06/02/11 02:17 PM
06/02/11 02:17 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Rob if u have the mazooma$ invest in a set of split leaf's and the rear rancho's they sell,they work awesome,there light they work, and not that much money,and customer service with CALVERT is 2nd to none
Re: Caltracs and 2" lowering blocks [Re: autoxcuda] #1004801
06/02/11 02:29 PM
06/02/11 02:29 PM
RobX4406 Offline OP
RobX4406  Offline OP
He sells lowering blocks? Too funny, I've bought a few sets of lugs off the net from the guy.
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004802
06/03/11 02:17 AM
06/03/11 02:17 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I had CalTracs and the split mono's on my Dakota. They wouldn't guarantee the 2" lowered height I wanted because I had a big block in the truck. I ended making a set of 1 7/8" lowering blocks out of 2x3x3/16 wall s/s rectangular tube..Got me right where I needed to be and had no issues running 11.70's with it.
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Caltracs and 2" lowering blocks [Re: RobX4406] #1004803
06/03/11 02:51 AM
06/03/11 02:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm pretty sure I've seen some in his swap booth. He's got great deals on billet wheel spacers too.
Call him, the website isn't very thorough.
Re: Caltracs and 2" lowering blocks [Re: fishy340] #1004804
06/03/11 07:02 AM
06/03/11 07:02 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i agree --- i was on the phone with them today for at least 15 minutes. Great guys. And for the record--EVERYTHING i was told by Calvert was 100% opposite of what the internet experts/keyboard racers post.
Re: Caltracs and 2" lowering blocks [Re: 493_DART] #1004805
06/03/11 03:13 PM
06/03/11 03:13 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Got mine at murrys,work great and there steel.
Re: Caltracs and 2" lowering blocks [Re: 493_DART] #1004806
06/04/11 12:27 AM
06/04/11 12:27 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
They are TOP notch and I'm glad I chose their product. When I have another worthy Mopar, it WILL have CalTracs under it.
