Re: Converting factory A/C fittings to AN
[Re: BulletBob]
#1004291
06/01/11 02:25 PM
06/01/11 02:25 PM
Posts: 26,017 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What compressor are you using?
[Re: BulletBob]
#1004294
06/02/11 04:00 PM
06/02/11 04:00 PM
John_Kunkel
Rio Linda, CA
On the original type compressors with a bolt-on flange I either make an aluminum block and thread it NPT for the AN fittings or cut off the factory pipes at the fitting and weld/braze the fittings onto the stubs.
