4 speed hump #1004052
05/31/11 09:15 PM
05/31/11 09:15 PM
Northern Virginia
barracuda7 Offline OP
Northern Virginia
Does this hump look right to you?
Re: 4 speed hump [Re: barracuda7] #1004053
05/31/11 09:48 PM
05/31/11 09:48 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Yes, it looks like a frog in an ice cube.
Re: 4 speed hump [Re: domingo] #1004054
05/31/11 09:59 PM
05/31/11 09:59 PM
Northern Virginia
Northern Virginia
I mean, does it look like factory hump or converted hump, can you tell by looking that pic?
Re: 4 speed hump [Re: barracuda7] #1004055
05/31/11 10:24 PM
05/31/11 10:24 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Your pic doesnt show for me!!! All I see is a frog inside an ice cube!!! LOL
Re: 4 speed hump [Re: domingo] #1004056
05/31/11 11:00 PM
05/31/11 11:00 PM
IN
ahy Offline
ahy  Offline
IN
I don't know what model/year the pic shows, but mine has a square cut out for the shifter that is farther forward ('70E).
Re: 4 speed hump [Re: ahy] #1004057
05/31/11 11:21 PM
05/31/11 11:21 PM
Northern Virginia
Northern Virginia
Its 67 barracuda 383 fastback.
I had 68 cuda notchback factory 4speed and the hump is way different with this 67. Hump in my car does not come out that much.
Re: 4 speed hump [Re: barracuda7] #1004058
06/01/11 05:54 PM
06/01/11 05:54 PM
Northern Virginia
Northern Virginia
This hump look like welded on top of the factory one, doesnt it? Anyone?
Re: 4 speed hump [Re: barracuda7] #1004059
06/01/11 06:20 PM
06/01/11 06:20 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I've done one A body 4 speed conversion. The hump looks right but it looks looks like it's been removed and moved toward the driver's foot well by adding a steel rim. Are there two pieces of metal there (Not including the floor pan? There should be one.) Possibly to compensate for an aftermarket shifter??? What's the frame crossmember look like? Is it butchered?
I’m listening.
Re: 4 speed hump [Re: Big Bad Bee] #1004060
06/02/11 12:55 AM
06/02/11 12:55 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Could you please post a smaller and crappier picture so we can tell what you have there .
Re: 4 speed hump [Re: JohnRR] #1004061
06/02/11 07:06 PM
06/02/11 07:06 PM
Northern Virginia
Northern Virginia
Its not easy to take crappier picture you know, but I'll try and post later.
lol
