Alternator Upgrade? #1003873
05/31/11 05:33 PM
05/31/11 05:33 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Recently installed EFI, electric fuel pump. Already had stereo/amp and digitial ignition system in there. I have a one wire 60amp Denso Toyota style alternator on the car.
The stock Ammeter gauge used to be close to 12 o'clock, now it holds pretty consistent at just below 20. I still show the battery charging at 14.0 volts. Am I going to need to upgrade the alternator to get the amp gauge closer to 0, or is it ok to run these kind of numbers? If my Volt gauge shows the correct battery voltage can I assume I have enough alternator for the job?
Re: Alternator Upgrade? [Re: Viol8r] #1003874
05/31/11 08:34 PM
05/31/11 08:34 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sounds like you better start by bypassing the Amp Gauge and the bulkhead connectors first before you go up in smoke.
Re: Alternator Upgrade? [Re: jbc426] #1003875
05/31/11 08:45 PM
05/31/11 08:45 PM
Medford OR
FrankenScamp Offline
Medford OR
http://www.madelectrical.com/electrical-tech.shtml
LOTS of good tech here....upgrades are only as good as the crappy old wiring that feeds them. Yes bypass the ammeter and drill the bulkhead. It's not hard.
Re: Alternator Upgrade? [Re: jbc426] #1003876
05/31/11 08:55 PM
05/31/11 08:55 PM
IN
ahy Offline
ahy  Offline
IN
Good idea. Also, if you wored up the EFI and maybe fuel pump directly to the battery or fender relay (as recommended) it confuses the ammeter. The ammeter thinks the power being used by the EFI is going to the battery and shows charge all the time.
Its time for a bulkhead bypass which can be as easy as a length of charge wire from the alternator to the fender relay with appropriate fusible link soldered in. Follow that up with a volt meter in the passenger compartment and you will be in better shape. The voltmeter will monitor system condition.
The 60 amp denso is likley marginal in your application but first priority is to get the load off the ammeter and bulkhead connector.
