Re: Idle Stop Solenoids
[Re: ScottSmith_Harms]
#1003740
06/01/11 12:08 PM
06/01/11 12:08 PM
Posts: 387 n/w, PA
demonH1B
n/w, PA
Can anyone go into detail on the round plunger top vs the hex top with wire connector. Which were used on what cars? Does it call for a different number?
[Re: 6T9Hemi]
#1003742
06/01/11 03:08 PM
06/01/11 03:08 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Can someone explain the function of the idle stops?
There is a base idle (solenoid not energized) so the car will shut off without dieseling. This is usually around 500-700 RPM With the solenoid energized, it pushes the plunger out, raising the idle so it idles smooth. This is usually around 1000-1100 RPM.
#1003743
06/01/11 05:14 PM
06/01/11 05:14 PM
Posts: 904 Berwyn, IL
Moparlar
Berwyn, IL
Each application calls for.a specific DR#
Is there a list of what number for what application. And I went and looked at mine and I have a hex head one with no number on it. What would that fit.
Larry
#1003745
06/01/11 09:42 PM
06/01/11 09:42 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the list from the old post here on Moparts.
3514520 Early (AVS) 3549318 Late (AVS) DR1114421 70 440 4737S,4739S, 4741S, 4740S Hex head with cap, no integral bracket
3514892 (AVS) DR1114442 70 340 4936S, 4937S Round head, no integral bracket
3438303 (AVS) DR1114442 or DR1114447 (Have reports of both) 70 440 4738S 71 440 4968S Hex head with cap, no integral bracket
3438777 (Holley) DR1114441 71 383 4667A, 4734A, 4668A, 4735A, 6191A, 6193A Hex head with cap, no integral bracket, but includes wiring harness
2875975 (Holley, AFB) DR1114429 70 440+6 4375A, 4734A, 4376A, 4144A 70 340+6 4791A, 4792A 70 426 4745S, 4746S 71 426 4969S, 4970S Round head with integral bracket
3438338 (Holley) DR1114443 71 440+6 4669A, 4670A Hex head with cap
3412059 (Holley) DR1114420 69 440+6 Hex head with cap
3438333 (Same as 2875975) (TQ) DR1114429 71 340 4972S, 4973S Round head with integral bracket
Bill Rolik
From an article by Frank Badelson:
69-1/2 440-6: DR1114420 (hex head) 70 340 4 bbl: DR1114442 (round head) 70 340-6 and 440-6 and hemi: DR1114429 (round head) 70 440 4 bbl: DR1114421 (hex head) 71 440 4 bbl: DR1114447 (hex head) 71 440-6: DR1114443 (hex head)
[Re: cudaized]
#1003747
06/01/11 11:48 PM
06/01/11 11:48 PM
Posts: 2,315 South, FL
cudaized
South, FL
re: 1970 340 What determined if the car (carb) received the idle solenoid? One of my 4933 has it, including that interesting extra power feed from the alternator. Another 4933 does not have it nor the power wire. I have 6 or 7 other 1970 340 carbs. Some have it some don't?
#1003748
06/02/11 10:25 AM
06/02/11 10:25 AM
Moparlar
Berwyn, IL
There is no (reliable) list that I've seen publicized but a few of us here on Moparts posted one a while back, I'll see if I can dig it up. In general, most cans with no stamped number and a small brass hex head are generic replacements.
I also have 1 with Stenciled #1114423 and a round head. I will assume this also a replacement.
At least I have a DR1114429 for my Superbird. Still have to find the correct one for my 72 6 pack car.
Larry
[Re: Moparlar]
#1003750
07/15/11 09:16 AM
07/15/11 09:16 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Larry
The 1114423 is not a generic replacement,it is O.E.M. Pontiac Ram Air 1V.
[Re: cudaized]
#1003751
07/16/11 03:45 PM
07/16/11 03:45 PM
Posts: 1,547 Puyallup, Wa.
Steve340
Puyallup, Wa.
re: 1970 340
If it had California emissions in 1970 it got the solenoid.
[Re: 62maxwgn]
#1003752
07/16/11 11:32 PM
07/16/11 11:32 PM
Moparlar
Berwyn, IL
Larry
Guess I should look for a pontiac guy to sell it to
[Re: Steve340]
#1003753
07/17/11 01:12 AM
07/17/11 01:12 AM
cudaized
South, FL
re: 1970 340
That's what I have been thinking, BUT, my original 1970 `cuda340 sold new in TN has it? (Hamtramck built) Just curious if there were other possible parameters that this solenoid would have been installed from the factory. [or even dealer installed]
Ola
[Re: RodStRace]
#1003754
07/17/11 08:21 AM
07/17/11 08:21 AM
Posts: 242 midwest
intragration
midwest
What controls when the solenoid is energized? I haven't had any problems with dieseling, but I have noticed that coming to an abrupt stop, the car briefly wants to stall before regaining it's composure. If this allowed idle to be higher at some times, but lower at others, this might be beneficial, but again, I don't understand what controls it's operation.
Don't feel too bad, lowly '70-'71 340 guys, there's always us '72-'74 guys out there.
[Re: intragration]
#1003755
07/17/11 10:43 AM
07/17/11 10:43 AM
cudaized
South, FL
The key in the "ON" position. It gets 12 volts from the alternator Field terminal. The plunger is directed to extend any time the electricity is present. When the key is first engaged, the plunger may not extend fully until the carb is opened a little (like to engage the choke on a cold start). Once the carb is opened a little, the plunger stays extended until the electricity is removed (ie. Turn the key to OFF).
