Page 3 of 4 1 2 3 4
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003488
06/08/11 01:52 AM
06/08/11 01:52 AM
SoCal
Brian Hafliger Offline
SoCal
pump gas 408 and solid roller cam!
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003489
06/08/11 01:53 AM
06/08/11 01:53 AM
SoCal
SoCal
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003490
06/08/11 05:03 PM
06/08/11 05:03 PM
SoCal
SoCal
That engine with those heads made 621HP this morning on pump gas. TQ was 541. Roller cam, 10.9:1, 1050, TTI 1 7/8 x 3.5" header.
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003491
06/08/11 05:10 PM
06/08/11 05:10 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Brian, do you mind sharing the specs on the cam? Intake? How much power/tq do you think it would give up with a 950 HP?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003492
06/08/11 05:20 PM
06/08/11 05:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
very nice I like the blacked out carb and valve covers.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003493
06/08/11 08:20 PM
06/08/11 08:20 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
What belt drive is that?
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Cudahlr] #1003494
06/08/11 08:24 PM
06/08/11 08:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It looks like a Jesel, can't see an idler/adjuster pulley for it to be a Weber
Alan Jones
Re: SB Edelbrock LA heads 304cfm@.600" [Re: LA360] #1003495
06/08/11 08:31 PM
06/08/11 08:31 PM
SoCal
SoCal
Yep, Jesel stepped up and helped us with the drive. It fits R3 blocks, but we fanangled it to work on a stock block with Meziere helping us with the water outlets so we could swap cams, and make adjustments easier and quicker.
Just ran out of time to make any more HP but I believe there is at least 5-10 more in it with porting the adapter and lash change but no time left...was a looooooong 2 days!
Brian
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003496
06/08/11 08:34 PM
06/08/11 08:34 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Impressive Numbers! Can we have anymore details? Did you happen to test it with any other headers?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Cudahlr] #1003497
06/08/11 10:07 PM
06/08/11 10:07 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Can you give us the cam specs on that Brian?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: SB Edelbrock LA heads 304cfm@.600" [Re: FlyFish] #1003498
06/09/11 12:43 AM
06/09/11 12:43 AM
SoCal
SoCal
Well...it's going in a mag, so I'll be vague. We tried TTI 1 7/8 x 3" and 3.5" collectors, spacers, moved the cam around, lash, 3 carbs, timing.
Father time was kickin' our but on this build and just ran out of time to try a different cam combo.
Cam was in the 260's @ .050 and lift was mid 600's.
OOTB 1000HP did very well against everything the PC 1000HP and PC dominator but the dommy was KING from 4000rpm to redline!
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003499
06/09/11 06:19 AM
06/09/11 06:19 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Nice work and nice HP numbers How did those heads do in flowbench? What size intake valve you used?
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003500
06/09/11 09:09 AM
06/09/11 09:09 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work IMM.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: HardcoreB] #1003501
06/09/11 10:26 AM
06/09/11 10:26 AM
SoCal
SoCal
Nice work IMM.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003502
06/09/11 10:27 AM
06/09/11 10:27 AM
SoCal
SoCal
295@ .500 and 305@ .700 with a 2.08 Manley valve.
Brian Hafliger
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003503
06/13/11 03:48 AM
06/13/11 03:48 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003504
06/13/11 03:57 AM
06/13/11 03:57 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Itīs a 408 pump gas street engine with 10.7:1 CR, MP .590" flat tappet cam and 1.6 rockers
Re: SB Edelbrock LA heads 304cfm@.600" [Re: Brian Hafliger] #1003505
06/13/11 07:18 AM
06/13/11 07:18 AM
Guitar Jones Offline
Oh man, everyone on the interweb knows a stock block won't take more than 600 horsepower.
Nice build and nice numbers. Hell some people were telling me I wouldn't make 650, and I have W5's and a tunnel ram. We'll soon find out though. Hopefully.
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003506
06/13/11 08:32 AM
06/13/11 08:32 AM
LA360 Offline
LA360  Offline
I make a nice compact set up for your block hardware for a remote oiling system, it would be a third as tall as the one you are running now
Alan Jones
Re: SB Edelbrock LA heads 304cfm@.600" [Re: mopster] #1003507
06/13/11 11:54 AM
06/13/11 11:54 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Looks like a nice build! Will this go on a dyno to be tuned,or straight to the car?
I think it will perform pretty well once you get it all dialed in.
Keith
Page 3 of 4 1 2 3 4
