rust bullet or just paint it? #1003387
05/31/11 12:43 AM
05/31/11 12:43 AM
United states wisconsin
bigblockbryan Offline OP
okay im building a dodge demon that i plan to do alot of drag racing(bracket racing) now heres my question should i do the car underneath in rust bullet. Or just paint it the car will also see a fair amount of street time too
Re: rust bullet or just paint it? [Re: bigblockbryan] #1003388
05/31/11 12:52 AM
05/31/11 12:52 AM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
If the underside is generally clean / minor surface rust, just clean, sand prime and paint.
I use and recommend rust bullet; I only used it on areas where more seroius rust was starting to creep....though it does make for good primer!
Re: rust bullet or just paint it? [Re: MoparDan] #1003389
05/31/11 01:06 AM
05/31/11 01:06 AM
the car pretty much 100 percent rust free im trying to keep this car light too but it will also be going down a gravel road quite often too my plans are to have seats no carpet headliner all steel body and go drag racing have a 340 that should run when put back togther. The goob took the perfectly running 340 aprt my plan is to put it togther and just have a car to drag race this year
