8 3/4 gear setup pattern? #1003077
05/30/11 04:26 PM
05/30/11 04:26 PM
mesa arizona
moturbopar Offline OP
mesa arizona
Hi all I am in the middle of setting up the gears in my 489 diff. This is my first time doing this by myself so I need a little help diagnosing my gear pattern. I think that I might need a littl more pinion depth. I set the pinion to the depth marked on the pinion gear, but it seems off to me. What is needed to be done here.
http://img.villagephotos.com/p/2005-10/1085523/diff%20005.JPG
http://img.villagephotos.com/p/2005-10/1085523/diff%20004.JPG
Re: 8 3/4 gear setup pattern? [Re: moturbopar] #1003078
05/30/11 05:35 PM
05/30/11 05:35 PM
Under My Car
Mopar_Country Offline
Under My Car
Your depth into the gear don't look bad, but your pinion needs to be set deeper. You want your pattern in the center of the ring gear.
You need to re-size your pictures smaller.
Re: 8 3/4 gear setup pattern? [Re: Mopar_Country] #1003079
05/30/11 05:41 PM
05/30/11 05:41 PM
mesa arizona
mesa arizona
Thanks that was what I was thinking. How much do you think I should try moving the pinion? I didnt realize the pics were that big! Sorry guys.
Re: 8 3/4 gear setup pattern? [Re: moturbopar] #1003080
05/30/11 05:44 PM
05/30/11 05:44 PM
Under My Car
Under My Car
Are you using the crush sleeve or the eliminator?
Did you use a shim at all?
Re: 8 3/4 gear setup pattern? [Re: Mopar_Country] #1003081
05/30/11 05:56 PM
05/30/11 05:56 PM
mesa arizona
mesa arizona
I am using a solid spacer, and has .029 shims. Preload is set at 22 in/lb, the instructions ask for 24 in/lb but 22 is the closest I can get.
Re: 8 3/4 gear setup pattern? [Re: moturbopar] #1003082
05/30/11 10:15 PM
05/30/11 10:15 PM
Under My Car
Under My Car
You are going to want to shim some more to get the pinion into the ring gear further.
Re: 8 3/4 gear setup pattern? [Re: Mopar_Country] #1003083
05/30/11 11:59 PM
05/30/11 11:59 PM
Under My Car
Under My Car
I think I have you going the wrong way, it looks like it too deep. I had to look at the pic again. If the pinion is drawn back it should get you in the center of the ring gear.
Re: 8 3/4 gear setup pattern? [Re: Mopar_Country] #1003084
05/31/11 12:07 AM
05/31/11 12:07 AM
mesa arizona
mesa arizona
Thanks, I will try changing it some more tomorrow. and I will post some more pics.
Thanks again.
Re: 8 3/4 gear setup pattern? [Re: moturbopar] #1003085
05/31/11 12:28 AM
05/31/11 12:28 AM
Under My Car
Under My Car
Here's mine that I did. My first one as well. It's probably not perfect, but it runs flawlessly. No noise or problems.
Re: 8 3/4 gear setup pattern? [Re: Mopar_Country] #1003086
05/31/11 01:59 AM
05/31/11 01:59 AM
mesa arizona
mesa arizona
Thanks that picture helps alot!
