coolant recovery system #1002936
05/30/11 12:49 PM
05/30/11 12:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..want to install a rad over flow system in my Duster.
..w/15 lb cap,system is pressurized until 15 lb is exceeded,cap opens and excess flows to reservoir...cap closes.
..how does it get back into rad if cap is closed...is this also a check valve for reverse flow when cool?
..what cap do i need for this, part # ???
..which newer tank adapts easily?
Re: coolant recovery system [Re: can.al] #1002937
05/30/11 12:53 PM
05/30/11 12:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes, there is a one-way valve on the bottom of the cap--look for the metal dime-sized 'button'. You can pull it down with very little force, the force that does that is vacuum in the cooling system as it cools and contracts.
Very simple, very effective
As far as tanks you NEED on that draws from the bottom--either by the hose connecting to the bottom of the tank or a tube from the top cap that extends down to the bottom of the tank
Re: coolant recovery system [Re: can.al] #1002938
05/30/11 12:54 PM
05/30/11 12:54 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
as system cools, a vacuum is created,pulling coolant back in.. any bottle will work, as long as the hose is at the bottom and the top is vented. any standard cap will work. you are making it more complicated than need be. you can get a nice aluminum tank, or slide a hose into a half full antifreeze jug. its that simple
Re: coolant recovery system [Re: Youngblood] #1002939
05/30/11 12:59 PM
05/30/11 12:59 PM
He needs a cap with the button, most caps have them these days, but they still sell caps without.
Re: coolant recovery system [Re: Pacnorthcuda] #1002940
05/30/11 02:28 PM
05/30/11 02:28 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..tx guys
..can't help but think i'm leaving some cooling capacity on the table with that top tank always low.
..now to find something that's a good fit.
Re: coolant recovery system [Re: can.al] #1002941
05/30/11 02:51 PM
05/30/11 02:51 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Way easy to do. We are putting a recovery system in a challenger this week. Guy hates the anitfreeze puddles it leaves and wants to cleaner with it.
Re: coolant recovery system [Re: can.al] #1002942
05/30/11 03:23 PM
05/30/11 03:23 PM
that's actually why it was invented was it dropped temps as much as 10 deg F when an inventor patented it back in the 70's & the car companies had to pay royalties. Side bennie from it was the elim of air lessened rust buildup & yes the puddles
