Carburator Fuel "leak down" problem #1002367
05/29/11 08:28 PM
05/29/11 08:28 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
A customer of mine has a new MP six pack on his 440.
If he leaves the car sit for a week or so, the carbs seem to empty themselves out only leaving enough fuel to MAYBE fire once. Then you crank and crank and crank and crank and crank and nothing happens...
You remove the shaker bubble PITA, and pour gas down and she fires right up and works perfectly fine with all the float bowls adjusted and working properly...
Let it sit again and it's the same process all over again...
What would cause the fuel system to empty out like that ?
CHECK OUT MY NEW WEB SITE !
Re: Carburator Fuel "leak down" problem [Re: anlauto] #1002368
05/29/11 08:44 PM
05/29/11 08:44 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It's most likely evaporating not draining. Modern gas is crappola. EXTREMELY common problem these days.
Re: Carburator Fuel "leak down" problem [Re: anlauto] #1002369
05/29/11 11:42 PM
05/29/11 11:42 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Yeah..you almost need an electric fuel pump to keep from cranking the engine so much.
Re: Carburator Fuel "leak down" problem [Re: 52savoy] #1002370
05/30/11 12:16 AM
05/30/11 12:16 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
little mallory pump out back by the tank.. sure saves a lot of cranking! dan
Re: Carburator Fuel "leak down" problem [Re: ph23vo] #1002371
05/30/11 10:37 AM
05/30/11 10:37 AM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
Alan,
This is a common problem on 440-6 and 340-6 Holley 2300's. I have the same issue on my T/A.
If it sits for more than 3 or 4 days, I have to crank before it fires.
B5 Challenger T/A
Re: Carburator Fuel "leak down" problem [Re: anlauto] #1002372
05/30/11 10:44 AM
05/30/11 10:44 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
I had a problem with the fuel pump rod on a BB. Not hardened and it was wearing out on the cam side.
If the car has not stalled when driving then it is more likly the bowls have emptied when sitting.
performancecarrestorations.com
Re: Carburator Fuel "leak down" problem [Re: moparo] #1002373
05/30/11 11:04 AM
05/30/11 11:04 AM
SE Pa.
LimeliteAero Offline
SE Pa.
been dealing with this on a 440+6 since 85 when I bought it. would love to hear some solutions for when I get it back together.
Re: Carburator Fuel "leak down" problem [Re: LimeliteAero] #1002374
05/30/11 11:36 AM
05/30/11 11:36 AM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
I also think its evaporation since I pretty much have that problem with all my cars, some worse than others maybe depending on engine cranking speed and fuel pump condition.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Carburator Fuel "leak down" problem [Re: mopargem] #1002375
05/30/11 11:53 AM
05/30/11 11:53 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have the same problem on all my Mopars with AFB, Holley 2300 & 1920, Carter BBD.
There is one exception, I have a slant six I run a Holley 2300 500 on, it can sit 4 weeks, pump it twice and it will fire immediately. I have no answer to why the gas doesn't evaporate out of this carb.
Re: Carburator Fuel "leak down" problem [Re: B5 Bee] #1002376
05/30/11 02:57 PM
05/30/11 02:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i've been wondering, if the "pre-lube" oil set up, that holds some oil under pressure, to pre-lube a high performance motor, could be plumbed into the fuel system? would store a bit of gas under pressure (4-6 psi) and could be used to refill the carb(s) after sitting a while? with the new carbs being aluminum instead of zinc, and gas being corrupted with alcohol, something needs to change. it's sure not going to get any better, if the damned corn growers have their way.
Re: Carburator Fuel "leak down" problem [Re: Golden-Arm] #1002377
05/30/11 06:17 PM
05/30/11 06:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
heat from manifold is boiling the fuel away? hot gas evaporates faster the cold gas, also i think they formulate the gas that way to sell more. it is very bad. we used to run cam-2 purple in the race car and it would evaporate each week, went to cam-2 blue and never had the problem again, different evaporate rates.
Re: Carburator Fuel "leak down" problem [Re: cudaman1969] #1002378
05/30/11 06:49 PM
05/30/11 06:49 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Buried in my notes for initial 440-6 startup is to fill the float bowl via the vent tube until you can see the pump spray
Re: Carburator Fuel "leak down" problem [Re: anlauto] #1002379
05/30/11 09:55 PM
05/30/11 09:55 PM
Rocky Hill, Ct
Roadcuda Offline
Roadcuda  Offline
Rocky Hill, Ct
I have a '64, and '65 Barracuda with Commando 273's, and a '69 Roadrunner with a 383 and have that problem all the time when they sit for more then 4 or 5 days or more. When I go to start any of them I don't even set the choke until I let it crank for a bit to pump the gas up to the carb.
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
