Any ideas why 72 Challenger is overheating?
#1002163
05/29/11 03:37 PM
05/29/11 03:37 PM
Posts: 9 Los Angeles, CA, USA
Hessian13
Hi everyone, I have a 72 Challenger with a 318 that has been running super hot since the weather got warm. I replaced the thermostat, since it seemed nearly dead, and the water seems to be flowing in the radiator so I think the pump is working. The fan works too.
The car hasn't overheated yet officially, but the temperature gauge goes past the H pretty often and can stay there for quite a while unless the car is moving (so that the air is flowing, I guess.)
If anyone has any ideas I would appreciate it; I'm scared she'll overheat if I'm stuck in traffic too long or once the hot weather really kicks in. My heater is disconnected and the fan for it doesn't work, so I can't draw off the excess heat by flipping it on, either.
Thanks so much! --Ann
Re: Any ideas why 72 Challenger is overheating?
[Re: Hessian13]
#1002164
05/29/11 04:43 PM
05/29/11 04:43 PM
Posts: 21,666 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
antifreeze could be old, will loose some disipaton after a couple years of use.
thermostat could be incorrect for what your running. Do you know what size it is? I once had a new one not work, had to put it in boiling water to see if it would open. Check radiator cap see if it is needing replacment. Some hoses Could also be colapsing and keeping coolant from flowing properly.
Did you check the belt to see if it is worn smooth and could be slipping on the pulley?
COuld the radiator be partially blocks, some of the cores near the center could be clear and the outer ones could have some rust or scale.
One time with a 1969 318 engine, we had a similar problem. had replaced everything and nothing. had a service shop performe a full collant flush and found out there was lots of buildup in the water jackets and that was blocking enough collant from going through to cool the motor.
Be sure to have your check list handy incase you need to trace your steps back a bit, sometimes a little change can be the culprite.
[Re: scatcity]
#1002166
05/29/11 05:07 PM
05/29/11 05:07 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
Does the hose have pressure on it?If so the cap should be ok.If no pressure could be alot of things,does it seem to "use up" the antifreeze?Is the mix 50-50?To much antifreeze will make it over heat.Even a to lean of cylinder conditon can cause a out of the blue "normal" area increase.Any timing changes?
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
[Re: migsBIG]
#1002168
06/09/11 04:31 PM
06/09/11 04:31 PM
Hessian13
Hey Mig, thanks for your response! Got a scratched cornea (ouch) that kept me off the computer for a while because the screen was too bright too look at, but all better now.
I did check the new thermostat and it seems to be working - boiling was a great tip, thank you! Adding more water to dilute antifreeze seems to help a little, too, but I think you're right about the blockage in the radiator...I notice the car will sometimes suddenly *stop* running hot for awhile, and that seems to have nothing to do with how hard she's working or how long she's been running; it's totally random. Which makes it seem like there's a partial clog that isn't always blocking the flow.
My shop's going to help me flush it before the weekend, so I hope that solves it. I'm glad you brought this up; I hadn't given it serious thought since all looked fine and rust-free on the surface. Thank you so much for your help!!
