Early BB motor mount question
#100192
08/05/08 01:52 PM
08/05/08 01:52 PM
Posts: 1,143 Imlay City, MI
DTT
super gas
super gas
Imlay City, MI
Im putting together a 383 from a 62' Chrysler. My question is regarding the motormounts and the attachment to the block. It seems theres some heat type shields that mount to the block. I was wondering the correct way these go. There seems to be a preety good gap between the block ear and the actual motor mount.... Am I missing something?? Thanks
1978 Pro Street D100
1936 Dodge truck (Hot rod)
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
1995 Jeep Grand Cherokee
1971 Big Block Demon (Dads)
Re: Early BB motor mount question
[Re: DTT]
#100195
08/07/08 03:53 PM
08/07/08 03:53 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I believe that '62-'65 B bodiy mounts are the same. I am not sure about the C bodies though. This is going back into a '62 full size Chrysler, right?
This is the land of the free
because of the brave
[Re: rbstroker]
#100196
08/07/08 05:43 PM
08/07/08 05:43 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
You don't really 'need' the shields. But they do shield some heat and more importantly, oil from the mounts. One way to beef up these mounts so they won't fail ever again, is to drill one or two holes right through them, and knock some steel rods into them and weld the ends. That's how I always modify these mounts.
[Re: BigBlockMopar]
#100197
08/07/08 06:48 PM
08/07/08 06:48 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Just call Steve at Imperial Services.He makes a bulletproof poly mount for them.My kid has them in his 62 300 and after 6 years of abuse they are still like new.Rocky
Chrysler Firepower
[Re: therocks]
#100198
08/11/08 08:26 AM
08/11/08 08:26 AM
DTT
super gas
super gas
Imlay City, MI
I have an original factory manual for the car and cant find a detailed picture of how these shields go. I understand that Imperial makes a mount for these, But I want the engine to appear factory...so Im trying to figure out the correct way these shields mount. Thanks
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: John_Kunkel]
#100200
08/11/08 03:36 PM
08/11/08 03:36 PM
'62 B-body is slightly different from 63-65 which are completely different than the C-body mounts shown here.
#100201
08/11/08 06:08 PM
08/11/08 06:08 PM
Posts: 25,941 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'62 B body motor mounts are a mixed bag, the very early 318 used a one-piece mount very similar to the C body mount pictured above, later in the year they changed to the traditional 2-piece mount. The BB used the same insulator as the later 318 but incorporated a one-year-only wedge shaped bracket between the insulator and the K-member.
[Re: John_Kunkel]
#100202
08/12/08 09:42 AM
08/12/08 09:42 AM
DTT
super gas
super gas
Imlay City, MI
Thanks. I got the mounts on last night, and noticed a large gap between the back of the mount and the heat shield...
I just made some spacers up out of round stock. Im not sure if it is how it was, but it will work.I just got a long enough bolt so I could tighten the mount to the block, install the spacer and then put another nut on the outside of the shield...
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
