318 valve stem height #1001448
05/28/11 04:13 PM
05/28/11 04:13 PM
California
70SportSatellite Offline OP
super street
super street
California
not familiar enough with the small block to know but I am working on a 1970 318 and the exhaust valves are of equal height and are also higher than the intake valves around a 1/16th of an inch more or less. i did not measure it. Is this normal?
Re: 318 valve stem height [Re: 70SportSatellite] #1001449
05/28/11 05:13 PM
05/28/11 05:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Installed valve spring height should be right in about 1.68 (1.67-1.70) Relatively level across all 8 valve stems per head. If they IMO the valves are not in the seats correctly. either too deep for some or not deep enough for others.
Re: 318 valve stem height [Re: MoparforLife] #1001450
05/28/11 05:38 PM
05/28/11 05:38 PM
California
super street
super street
California
I would have that they should be equal also. I did measure the difference and the intakes are between .065-.075 lower than the exhaust. It's as if somebody set the stem height that way. The engine has been rebuilt at some point.
Re: 318 valve stem height [Re: 70SportSatellite] #1001451
05/28/11 06:42 PM
05/28/11 06:42 PM
Upper Midwest
Upper Midwest
Why would they. The spring is what is set to installed height and they are all (intake & exhaust) set at the same installed height. What you are getting is a seating variance as I stated above.
Re: 318 valve stem height [Re: 70SportSatellite] #1001452
05/28/11 09:06 PM
05/28/11 09:06 PM
Is this normal?
No but it'll work OK. Prob the ex seats were recessed from extended no lead use and the seats not being hardened and they had to grind em extensively to get a good pattern.
Re: 318 valve stem height [Re: RapidRobert] #1001453
05/28/11 09:30 PM
05/28/11 09:30 PM
Upper Midwest
Upper Midwest
Or somebody doesn't know not to bear down on the seat grinder. Personally I would have them done right. The exhausts will not last long cut into the head that way. As a rule Mopar heads seem more tolerant of UL gas and seem to have a harder seat than brand X but once that surface is cut down like you say it is not a good thing and they won't last long.
Re: 318 valve stem height [Re: MoparforLife] #1001454
05/29/11 01:42 PM
05/29/11 01:42 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
It seemed to me that all the heads came this way from the factory. If you are running a mild hydraulic cam, it will compensate for the difference.
Floyd Lippencott IV
