Stripping paint from an Argent `Cuda grille #1000953
05/27/11 07:52 PM
05/27/11 07:52 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I need to strip a Cuda grille of its original argent paint and it needs to be color keyed to the car. I figure the best ways would be soda blasting with real low pressure and a large nozzle opening with a fair distance. Any easy home remedies?
Re: Stripping paint from an Argent `Cuda grille [Re: UCUDANT] #1000954
05/27/11 08:09 PM
05/27/11 08:09 PM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline
Q
I would try lots of laquer thinner and a small brush before I would go on it with any kind of blaster. Then sand the rest of the bumps off with sandpaper. Those grilles are extremely delicate. It's gonna be very time consuming to go from textured argent to body color, the other way around is much easier.
Re: Stripping paint from an Argent `Cuda grille [Re: Quicksmopars] #1000955
05/27/11 11:45 PM
05/27/11 11:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When I restore Cuda/Challenger, or A body grilles finished in Argent, it's best removed using Laquer thinner, on clean white rags, or brush for tight areas, don't dwell too long with the solvent in one area, it will soften the ABS grill areas/parts,...just work the entire grill until most of the argent is removed, then you can focus on concentrated/or hard to reach areas,...
Mike
Re: Stripping paint from an Argent `Cuda grille [Re: UCUDANT] #1000956
05/28/11 01:53 PM
05/28/11 01:53 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks guys
Re: Stripping paint from an Argent `Cuda grille [Re: UCUDANT] #1000957
05/30/11 11:16 AM
05/30/11 11:16 AM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Oven cleaner works best to remove paint from plastic.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Stripping paint from an Argent `Cuda grille [Re: rexus31] #1000958
05/30/11 11:29 AM
05/30/11 11:29 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, it sure does, it also works well to remove plastic from plastic.
These grilles are made of ABS, ABS is more sensitive to solvents and other caustic chemicals than many other types of plastics (The "S" in ABS stands for styrene, ever put gasoline in a foam cup?).
Be careful what you put on that grille!
Re: Stripping paint from an Argent `Cuda grille [Re: ScottSmith_Harms] #1000959
05/30/11 11:05 PM
05/30/11 11:05 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
I had very little time into prepping this argent grill simply wetsanding it.
Re: Stripping paint from an Argent `Cuda grille [Re: N9671X2] #1000960
06/04/11 11:15 AM
06/04/11 11:15 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks I'll try that. What grit did you start with?
Re: Stripping paint from an Argent `Cuda grille [Re: UCUDANT] #1000961
06/04/11 04:09 PM
06/04/11 04:09 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
I THINK 400? No insult, but you will find your over thinking this once you grab a garden hose and some sand paper. I doubt I had 15 minutes into removing the argent. Buddy shot it in primer/b5 with a gun and turned out beautiful.
Re: Stripping paint from an Argent `Cuda grille [Re: N9671X2] #1000962
06/04/11 06:18 PM
06/04/11 06:18 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
THANKS again. I hope mine goes like yours did. I'll let you know. Hope to get to it this weekend
Re: Stripping paint from an Argent `Cuda grille [Re: UCUDANT] #1000963
06/07/11 11:24 PM
06/07/11 11:24 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I test sanded a portion tonight and it went real fast...thanks again
