Re: Your experience with custom piston manufacturers ...??
[Re: dOc !]
#1000814
05/27/11 03:07 PM
05/27/11 03:07 PM
Posts: 20,696 in a cattle trailer down by th...
Guitar Jones
I've bought custom pistons from Ross, about $700 but that was more than 15 years ago. The last set I bought were Wisecos at about $1000. Never had any problems with either of them.
[Re: dOc !]
#1000817
05/27/11 03:13 PM
05/27/11 03:13 PM
Thumperdart
State of confusion
My machinest ordered some custom JE pistons and pins for my last build and they were spot on, delivered in a timely fashion and cost $887.00 through him(I know). No complaints other than the mark up.....
[Re: dOc !]
#1000818
05/27/11 03:32 PM
05/27/11 03:32 PM
Guitar Jones
Did you get an extra one ?
No I did not. I figure if I need an extra one I got more problems than just a piston. Besides they will usually only make them in lots of 4.
[Re: HPMike]
#1000825
05/27/11 07:14 PM
05/27/11 07:14 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Bought a set of Cp's and 043 rings to go with them a few years back, about a grand, zero problems..
If they are correctly told exactly what a person wants done, most all of them are mighty sharp.
[Re: B3422W5]
#1000826
05/27/11 10:00 PM
05/27/11 10:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Ross and Diamond I have had good luck with. Rick at CP would do anything to help you also.
I prefer Ron at Diamond the most.
Leon
[Re: Leon441]
#1000827
05/27/11 11:06 PM
05/27/11 11:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have bought Ross, Diamond, Venoila,and CP... never had any problems but I prefer CP and Diamond due to cost Diamond is probably the cheapest on customs ![](/ubbthreads/images/graemlins/wave.gif)
