What is the pinion angle ? #1000414
05/26/11 07:12 PM
05/26/11 07:12 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
What is the correct pinion angle on a A-body with SS spring ?
Dan
Re: What is the pinion angle ? [Re: Wedgeman] #1000415
05/26/11 07:15 PM
05/26/11 07:15 PM
fresno ca
mikeysmopars Offline
fresno ca
4 DEGREES AUTOMATIC 6 DEGREES 4 SPEED
Founder and CEO of the Central Valley Mopar Drag Pack
Re: What is the pinion angle ? [Re: mikeysmopars] #1000416
05/26/11 07:21 PM
05/26/11 07:21 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Nose down ? 4 deg from the level or the difference between the angle of the drive shaft ?
Re: What is the pinion angle ? [Re: Wedgeman] #1000417
05/26/11 08:57 PM
05/26/11 08:57 PM
organ
maximum entropy Offline
organ
ss springs are supposed to be 7° nose down pinion in relation to tranny output shaft. here we go!!!!!!
Re: What is the pinion angle ? [Re: maximum entropy] #1000418
05/26/11 09:07 PM
05/26/11 09:07 PM
Super Scamp Offline
Super Scamp  Offline
HERE WE GO !!!!!!!!!!!!!! CAR ON THE GROUND 6 TO 7 DEGREES DOWN AND NEVER LOOK BACK.
NEXT EXPERT
Just One Man's Opinion Mopar Mafia Racing
Re: What is the pinion angle ? [Re: Wedgeman] #1000419
05/26/11 10:11 PM
05/26/11 10:11 PM
The way the driveshaft angle was defined by the Chrysler engineers in the old drag seminars was the difference between the pinion angle(with it nose down) and the driveshaft angle If the driveshaft angle is set at 90 degrees on your angle finder (pointer straight up) then the pinion angle should be 83 degrees nose down to get 7 degrees difference, if looking from the side of the car towards the angle finder, it will be 83 degrees one way and read 97 degrees the other way Chrysler never really discussed the trans angle in the seminars(3 or 4) I attended back in the dark ages before the internet You will hear a lot of discusions on pinion angle on this forum based off of the trans angles in relation to the pinion angle Here we go agian , QUICKTREE where are you
Re: What is the pinion angle ? [Re: Cab_Burge] #1000420
05/26/11 11:47 PM
05/26/11 11:47 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks for the infos guys...
Always back to basics!
Dan
Re: What is the pinion angle ? [Re: Wedgeman] #1000421
05/26/11 11:57 PM
05/26/11 11:57 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Pinion snubber, caltrac, ladder bar or nothing? they all take something different.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What is the pinion angle ? [Re: bigtimeauto] #1000422
05/26/11 11:59 PM
05/26/11 11:59 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: What is the pinion angle ? [Re: moparniac] #1000423
05/27/11 12:47 PM
05/27/11 12:47 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I don't agree that 0* is the optimal operating angle. Vibration and power wise - certainly. But a u-joint needs 1-2* of operating angle to keep the joints from brinnelling, and that small amount will not cause a loss of power or vibration.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: What is the pinion angle ? [Re: Evil Spirit] #1000424
05/27/11 01:53 PM
05/27/11 01:53 PM
organ
organ
0° is the optimum operating angle under full acceleration, hence the 7° nose down pinion angle. 7° is the typical amount of rear axle housing rotation under full acceleration with ss springs. 0° between the output shaft of the transmission and the pinion. the output shaft angle plays an equal role in determining pinion angle. pinion angle can be adjusted using the output shaft as well as the differential housing. remember to have the suspension loaded as well. if the angle is set without considering output shaft angle, your actual pinion angle will likely be incorrect.
Re: What is the pinion angle ? [Re: maximum entropy] #1000425
05/27/11 02:23 PM
05/27/11 02:23 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
You can take the driveshaft, stick it in a hole and mount your mailbox on it for all it affects PINION ANGLE. Pinion angle is the angle of the centerline of the engine/trans compared to the centerline of the pinion. You want these centerlines parallel under power. About 1-2*'s of u-joint angle helps joint life. This has been beat to death before - the driveshaft doesn't even have to be in the car to check or set pinion angle.
Re: What is the pinion angle ? [Re: Evil Spirit] #1000426
05/27/11 02:27 PM
05/27/11 02:27 PM
organ
organ
WINNAH!!!!
Re: What is the pinion angle ? [Re: maximum entropy] #1000427
05/27/11 02:48 PM
05/27/11 02:48 PM
PA
moparacer Offline
moparacer  Offline
PA
X1000!!
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
