Quote: I think the balance is diff so flex plate/tc and you need a LA timing cover and the Hughes' front cam adapter to run a mech fuel pump (it's dirt cheap). Prob more but this'll get you started
5.2 and 318 the same as far as balance, 360 and 5.9 are different.
