Looks great. Out of curiousity what cam are you running? Also are those straight or angled plug heads? If angled, what headers did you use?
I've been thinking of switching over to an easy efi from a gen VII I have been running for years. It's still a bit finiky and considering I built the car for my father I don't like to have to take time to mess with it if necessary. Thanks for your input.
Thanks. I run the Lunato Voodoo 60304 hydraulic cam. Straight plug Stealth 84cc heads with a little massaging done. I think you will be happy with the upgrade. Word on the street is this will be the similar set-up that the NASCAR boys are switching over too. So expect a lot use of these EFI products.
