I was unable to find Type F at wally world by the gallon. I use the cheap Vtech Dexron Mercon. Had good luck with it.
Just tried the hydrastatic trans hydrualic fluid. It was thick and made the converter act lazy. Was told it would lower the stall but the Racepac said otherwise.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
