For years a normal oil change in my race car also meant the same oil went into the tow vehicle.We only used regular oil but changed it maybe 50 passes in a 12 second stocker.
You use 200 miles as the factor in determining the overall amount it was used. In something like a fire engine how many HOURS was it been used would be more relative to it's condition.
Hours on all heavy equipment. We used 100 hours = 3000 miles as a general conversion rule. All heavy equipment will come with an hour meter, and their ( diesel Mfg )suggested change interval will be in hours. I have never seen an oil change interval less than 200 hours except on street sweepers. Maybe the chief ment hours? 200 miles = 15 hours. Ridiculous.
Absolutely correct. It's hours not miles on these kinds of vehicles. Idling can be worse than hard use.
Fastest 300
