I wouldn't use that head gasket, it's twice as thick as stock so it's going to lower your compression, unless that is why you are using them.
As said no sealer , BB head bolt holes are DRY.
What headgasket do you recommend?
Do you know what the mopar kit comes with cuz thats what I got...and its not steel shim..
Dan
Mopar Performance P4286754 from Summit .020 compressed thickness.
The standard Felpro 8519 is .039
