swaping a set of rebuilt heads onto my 67 383 schould I put thread sealant on bolts around water jacket bolts ? I have arp sealant and arp lube . I heard not to run a tap down the bolt holes takes off to much metal ? going to reuse factory bolts just a stock rebuild . I got felpro gaskets 8519 pt-1. any thoughts ? thankyou
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
