ok thanks Danny I'm going to {try and}determine whether I'm getting an accurate finish line reading from the Biondo Box. I see it has a play back feature, hopefully the data isn't lost once the power is off. This would give me "when" the engine hit the peak rpm. would it seem reasonable that if the trans/converter is slipping I could still have a good and constant ET and MPH?
