I've been experiencing some issues with mine, and from what I gathered if the booster is failing or has failed it would result in a hard pedal and diminished stopping power from a driver standpoint. What you're describing almost sounds as if you may have a small leak. Have you checked for a leak? With the pedal dropping further than normal, I would look there. It could be you need to adjust the rear brakes, if they are out of adjustment that can cause the pedal to drop more than normal. Just a couple of thoughts for you to consider.
It's a hydralic problem. You are only stopping on one set of brakes. Jack car up and see which brakes are not working. Or look for fliud loss, I'm sure that's the problem.
