first check the condition of the lines, if good then try a vacuum gauge and see if the booster holds pressure if not have it replaced . it easy just unbolt from peddle and firewall and unbolt master and pull out of the ay (check for seal leakage from the master if there is r/r) also make sure the check valve is good.
