No, I am not having problems with the weights. It looks like the center pipe had a crimp fit to the bottom plate, mine is loose. I can hold the bottom of the plate and twist the pipe from about 12 o'clock to 3 o'clock. I can do this with the assembly in my hand. seems like that should be a solid piece.
